Alignment Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chachie, Feb 13, 2010.
  1. Feb 13, 2010 at 12:37 PM
    Chachie
    Chachie [OP] Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    So i went to get my truck aligned this morning after installing the new xmember last night and getting everything lined back up again. And here is what they came up with:
    Any ideas why the right front camber is out so far? He said that it was at max adjustment and that something could be bent. Any ideas on what to check?
    Justin
  2. Feb 13, 2010 at 5:22 PM
    Chachie
    Justin
    Nor Cal
  3. Feb 13, 2010 at 5:38 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Your first check is lower control arms, bolts that hold them, bushings. Did you had any accidents?
    How much lift you have and how big tires you have ?
  4. Feb 13, 2010 at 6:12 PM
    wvtac0
    wvtac0 Well-Known Member
    Eastern Panhandle - WV
    17 TRD DC Sport
    Have you had T-SB-0305-08 accomplished?
  5. Feb 13, 2010 at 6:16 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    wait, is your truck the 6 inch with 35s or the stock with 265s
  6. Feb 13, 2010 at 6:47 PM
    Chachie
    Justin
    Nor Cal
    6" with 35's. And what is t-sb-0305-08?
  7. Feb 14, 2010 at 6:25 AM
    wvtac0
    17 TRD DC Sport
    TSB-0305-08 is the "Harsh Ride" fix. The TSB has new alignment data.
  8. Feb 14, 2010 at 7:11 AM
    Brunes
    Brunes abides.
    Rotorhead
    Does it actually CHANGE the alignment numbers or just say to recheck the alignment??
    Cause anytime you lift and lower a truck you need to ensure the alignment is right...but "right" is back to the factory specs in most cases unless you do some SERIOUS modifications.
    OP....Not sure what to tell you man. Good luck!!
  9. Feb 14, 2010 at 7:50 AM
    wvtac0
    17 TRD DC Sport
    I am looking at the TSB and it states the following at the top of page 8 of 18:
    "An alignment inspection and adjustment is required after the installation of the new rear leaf springs. The NEW alignment specifications are provided below:".
    With Toyota supplying new data, I would take it that the data that most alignment shops have in their computers would not apply.
  10. Feb 14, 2010 at 7:53 AM
    Brunes
    Brunes abides.
    Rotorhead
    ::is lazy and not really all that worried about it::
    ...but what are the numbers??
  11. Feb 14, 2010 at 8:04 AM
    wvtac0
    17 TRD DC Sport
  12. Feb 14, 2010 at 8:04 AM
    Chachie
    Justin
    Nor Cal
    Well either way I don't have the tab done cause my dealer is a douche and a half. The only thing I can thing of is that the front xmember is shifted too far to one side. Causing the lower control arm to be pulled in or pushed out on one side.
  13. Feb 15, 2010 at 11:57 AM
    Chachie
    Justin
    Nor Cal
