Alignment issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neumann86, Aug 23, 2024.
  1. Aug 23, 2024 at 1:19 PM
    Neumann86
    Neumann86 [OP] Member
    Neumann
    2014 Tacoma V6 4WD
    Full auto window switches, all new suspension
    So I just finished charging a bunch of suspension and steering parts on my 2nd gen. Took it to get aligned and then I locked the wheel all the way to make a 3 point turn. Then my steering wheel is off again. I’m taking it back to get fixed but does anybody know why this happened?
  2. Aug 23, 2024 at 1:57 PM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Inspect the camber / caser tabs to make sure they are in good shape and don't allow the cams to move. They often times get bent from offroading or from a bad alignment tech kranking on them too hard and will not hold an alignment then. A change in your camber can effect your toe and where the steering wheel sits then.
  3. Aug 23, 2024 at 2:30 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    What parts?
    Bishop84 likes this.
  4. Aug 23, 2024 at 5:01 PM
    TacoTuesday1
    SD CA
    they are not cranked too hard. They are made out of tinfoil unlike any other car. Any other car does not have this problem.
