Alignment/Lift Advice
Discussion in 'Suspension' started by bassfan, Jun 20, 2012.
  1. Jun 20, 2012 at 3:31 PM
    bassfan
    bassfan [OP] Well-Known Member
    Fort Worth
    2012 Super White Double Cab TRD Sport
    5100s Eibachs
    Details: 2012 DCSB TRD Sport 4x2
    Toytec's Eibach Springs
    5100 shocks (set at 0 lift)
    Moto Metal 16x8
    Hankook Dynapro tires
    Got a question for the truck guru's here. I put the shocks/springs on four or five months ago. I've had it aligned three times after getting lifetime alignment at firestone for cheap. Three different firestones...(Yes I've read threads where they aren't good)
    The truck just doesn't drive good. I had an 07 before with 5100s/stock springs and it was a lot better than this. I've read plenty on here about how they can give a "floating" feeling when the alignment isn't right. That's pretty much my experience. It's hugely wind sensitive, hard to keep on road in a stiff crosswind. It follows bumps/divets in the road really bad too. It just makes for an around annoying driving experience. I have told the alignment guys what I am looking for each time (camber and toe 0 and caster 2.4 or highest) Results are here for the last two times. They say this is as good as can get.
    Caster 1.9 1.7
    Camber .3 -.2
    Toe .04 .04
    Caster 1.8 2.3
    Camber .7 .6
    Toe .05 .05
    I know the caster is low and from reading it sounds like that is giving me the issues. My trucks a 4x2 and I got more lift than I was really expecting out of the Eibachs but it was no more than 2.5. Think it was around 2.25 actually. Tires/Rims are only one size up from stock and I hopefully not causing much issue.
    My question/options are this: Is it worth it to keep trying alignments at Firestone? Should I take it to a truck shop for an alignment and pay for that and see if they can do better? Should I go ahead and get new UCA's for it, slap them on and then take back to Firestone?
    thanks for any insight!
  2. Jun 20, 2012 at 5:49 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Those aren't good numbers...so you need to change something. UCAs are the easy first step.
  3. Jun 20, 2012 at 6:58 PM
    bassfan
    Fort Worth
    5100s Eibachs
    So it's been a while since I've been on the forum and I just noticed the alignment sticky. Sounds like I'm on track anyways with the problem. Thanks for the words Bruce.
    Anyone else have thoughts on the original options for my next step...otherwise it's time to shell out for uca's.
  4. Jun 20, 2012 at 7:00 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    its not toooooo bad
  5. Jun 20, 2012 at 10:10 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Personally I don't think you'll get it too much more dialed in. Those are absolutely symptoms of low caster and you won't get much better with the lift.
    Really the numbers aren't that bad but if you're not happy with the way it drives then I would just aim for new UCAs and then for 0, 0, 2.5+ and both sides the same.
