Alignment needed? Bilstein 5100 and TSB Leaf Springs
Discussion in 'Suspension' started by ShaneHD, Mar 16, 2011.
  1. Mar 16, 2011 at 11:11 AM
    ShaneHD
    ShaneHD [OP] Taco Tuesday
    Fort Worth TX
    2010 Tacoma CrewCab TRD
    I recently had the following done to the Taco:
    TSB Rear Leaf Springs
    Bilstein 5100's (all 4) (fronts set to 1.75")
    I noticed that the front tires are slightly bent in at the bottom of the tire. Is an alignment needed after having both of these done? I was told to give it a few days to see if it "bounces" itself out....but I don't think it will.
  2. Mar 16, 2011 at 11:16 AM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    its always good to get an alignment after changing suspension components. are the 5100's set at stock height or are they giving you lift?
  3. Mar 16, 2011 at 11:17 AM
    ShaneHD
    Fort Worth TX
    Where is the best and cheapest place to get an alignment done?
    I made the mistake of getting the TSB done before I put the 5100's on.
  4. Mar 16, 2011 at 11:20 AM
    ShaneHD
    Fort Worth TX
    I set the fronts at 1.75"
  5. Mar 16, 2011 at 11:20 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Go to Firestone, they have a lifetime alignment deal. I get my alignments done there all the time.. The lifetime deal isn't cheap, (i think $140) but in the long run it pay's off...
  6. Mar 16, 2011 at 11:25 AM
    DonL
    DonL Well-Known Member
    Don
    Prescott, AZ
    Tacoma TRD
    Monster Exhaust, Shell, 5100's all around, Airlift airbags, Hankook Atm, K&M air filter
    Yes, get an alignment. Also, I installed my 5100s front and rear. If you read the Toyota Installation instructions for the front shocks, it states to leave the bottom bolt on the front shocks finger tight until you put the tires on the ground. Then tighten them to factory specs. This allows the front end to settle.
  7. Mar 16, 2011 at 11:27 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    Definitely get an alignment then.
    The Firestone liftime alignment is a good deal, it ends up paying for itself in the long run. wish the firestone in my area offered them :mad:
  8. Mar 16, 2011 at 11:41 AM
    ds46000
    ds46000 Well-Known Member
    07 PreRunner TRD Sport
    i called firestone in my area....$179.99 + tax = $200!
    seems excessive.
    does anyone know of anyone else that does the lifetime alignments?
  9. Mar 16, 2011 at 11:45 AM
    krimson
    krimson Nothin
    TRD Off Road
    None what i know of... But really, is 180 too much for something that cost like idk $65 to do each time? If you didn't get it, you will only get 3 alignments for little over the cost of the life time.
  10. Mar 16, 2011 at 11:48 AM
    ShaneHD
    Fort Worth TX
    No way I am spending $200 on an alignment. Kwik Kar of Keller will do it for $59.95.
  11. Mar 16, 2011 at 11:57 AM
    ShaneHD
    Fort Worth TX
    Seriously, I don't have one close to me...so lets stop discussing them.
  12. Mar 16, 2011 at 12:05 PM
    ds46000
    shane, you should check out firestone...i heard they have a lifetime alignment deal.
    jk man, just giving you a hard time!
  13. Mar 16, 2011 at 12:50 PM
    ShaneHD
    Fort Worth TX
    Nice!
    Sure that may be the best deal overtime, but I don't have $200 to spend right now and don't have a Firestone near me.
    Pugga...please just leave the thread.
  14. Mar 16, 2011 at 1:18 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    call a different shop. most tire shops offer lifetime alignmet deals, not just Firestone... but still the price is most likely going to be around the same price whever you look.
