Alignment numbers, good, bad?
Discussion in 'Suspension' started by 4banger4x4, Sep 29, 2013.
  1. Sep 29, 2013 at 4:30 PM
    4banger4x4
    4banger4x4 [OP] Probably should'nt have done that.
    Eric
    Whorelando, Fl
    redid my whole front end this weekend and took it in to get aligned and these are the numbers
    front left, -0.4 camber, 2.8 caster, .11 toe
    front right, -.05 camber, 2.0 caster, .09 toe
    Total toe .20
    steer ahead .01
    left rear, camber 0, toe -.14
    right rear, Camber -.5 toe .33
    Total toe .19
    Thrust angle -.24
    The shop didnt touch my caster camber because they said the couldnt get there machine onto my wheels because there was not enough of a gap between my wheels and tires...:confused: but either way i have life time alignment at tires plus so my question is it worth finding a set of stock wheels so they can properly align my truck, go find a tires plus that can align my tires, or are these numbers fine?
  2. Sep 30, 2013 at 4:52 PM
    4banger4x4
    Eric
    Whorelando, Fl
