Alignment numbers
Discussion in 'Suspension' started by claymore, Dec 6, 2012.
  1. Dec 6, 2012 at 7:32 PM
    claymore
    claymore [OP] Well-Known Member
    Clay
    ABQ New Mexico
    2012 Offroad
    TRD cat back exhaust, console vault(for my little friend),Pop and Lock, Bak Flip G2, Weather Tech window covers, LED inside and out, DTRL Anytime, Grillcraft Grill, BAMF Light Bar with Hella 500s and Blitzpro 15D, Eibach with 5100's all around set at .85 and top plate spacers, LR UCA's, toytec 2" add a leaf, Duratrack 285 75 16, ABS kill switch, Aux reverse lights, Blue Sea Aux fuse block, ImMrYo Bracket, LED Bedlights, Ultra Gauge,
    Ok, I have searched and I am tired. I am getting an alignment after a 3 inch lift. Do I need to ask the shop for camber, caster and toe different then factory? What are the numbers? I have LR UCAs. Also, what needs to be done with the settings to get more room for 285s? Help please. I know I have seen this, but only have my phone, and searching is hard.
  2. Dec 6, 2012 at 7:47 PM
    trdNick
    trdNick Odie
    Texas
    07 Trd Off Road AC PreRunner Grocery Getter
    0* toe
    0* camber
    2.5-3.0* caster
  3. Dec 6, 2012 at 7:49 PM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    Are those numbers different from factory?
  4. Dec 6, 2012 at 7:53 PM
    trdNick
    trdNick Odie
    Texas
    Yes, the caster is. That is what the LR UCA's do, provide more caster. Just tell the tech what numbers you want. It will come up out of range on their machine but that's ok.
  5. Dec 6, 2012 at 7:59 PM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    Thanks. What do I need to do to get more space for the 285s. Is it something I do or is the caster what does it?
  6. Dec 6, 2012 at 8:01 PM
    trdNick
    trdNick Odie
    Texas
    Caster should help somewhat but every truck is different. It could range from just minor plastic trimming to a cab mount chop, or combined. You will just have to see where you are rubbing at full steering lock and flexed.
  7. Dec 6, 2012 at 9:14 PM
    Plik
    Plik Ragin Cajun
    Houston
    '11 DCSB PreRunner TRD Sport
    Click my sig pic for build thread
    Setting your LR UCAs to the +1 degree setting and adjusting more caster in your LCAs will move the wheel forward and should alleviate rubbing on the frame mount, but could require more trimming up front. What are your wheel and tire specs? "285s" doesn't give us much to go on.
  8. Dec 7, 2012 at 4:56 AM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    The tires I want to run are 285 75 16 on my TRD beadlock rims that have 4.5 bs. That is the info I was looking for, but now I wonder if it is worth it. Where is the trimming easier, front or back?
  9. Dec 7, 2012 at 7:31 AM
    Plik
    Plik Ragin Cajun
    Houston
    yep, I'd set your UCAs to the +1 degree setting and have the tech play with the lowers to get as close to 3 degrees of caster as possible. As stated above anything above 2.5 degrees should be suitable. Have him turn the wheels full lock in both directions and check for contact before taking it off the rack. You may have to sacrifice some caster for clearance. Trimming up front is way easier then a cab mount chop.
  10. Dec 7, 2012 at 12:13 PM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    Thanks for the help. Why is 2.5, 0, 0 the numbers? What is factory spec, and why are these numbers best for our trucks? I am just wanting to learn.
  11. Dec 7, 2012 at 1:49 PM
    Plik
    Plik Ragin Cajun
    Houston
  12. Dec 7, 2012 at 1:57 PM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2010 TRD Sport DC LB 4x4
    Work in progress, but installed so far; 265/70/17 Duratracs, Spidertrax, OME885X coils with OME lean spacer, OME N140S and N182 shocks, Wheeler's 1.5" 3 Leaf Progressive AAL (kept the overload), LR UCAs. TP14 spacers
    For what it's worth....Plik and Nick speak the truth. That is how I was told to set up my truck. SPC said adding the extra caster up top and adjusting on the bottom could improve your clearance inside the fender.
  13. Dec 7, 2012 at 2:40 PM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    Thanks a lot! I had read the second post when a lift was still way into the future. I remembered seeing the info but couldnt find it. This is just what I was looking for.
  14. Dec 7, 2012 at 2:40 PM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    Gracias:D
