Alignment numbers
Discussion in 'Suspension' started by BBBsti LTD, Jan 24, 2015.
  1. Jan 24, 2015 at 9:18 AM
    BBBsti LTD
    BBBsti LTD [OP] Well-Known Member
    Irvine, CA
    2010 TRD Off Road 4WD
    Please check my numbers. Truck has OME lift with trim packer but without .5" spacer and stock UCA.
    It drives nice and straight with no wander in the freeway.
  2. Jan 24, 2015 at 10:21 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    That's some low caster
  3. Jan 24, 2015 at 10:22 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    x2
  4. Jan 24, 2015 at 11:33 AM
    BBBsti LTD
    Irvine, CA
    It drive perfectly to me. How would that low caster affects the driving or tire wearing?
    Just curious
  5. Jan 24, 2015 at 11:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Low Caster, like your case, can cause more exaggerated bump steer, wandering, and less self centering of the wheels.
  6. Jan 24, 2015 at 11:53 AM
    BBBsti LTD
    Irvine, CA
    Thanks guys
  7. Jan 25, 2015 at 6:43 PM
    LomoTree
    LomoTree Junior Member
    Hank
    CT
    08 4x4 SR5
    Billy 5100's, OME 885s, 2" AAL
    Hey guys, this is my first post, not sure if it's in the right thread tho. I'm currently running about a 3 in. Lift in my 2008 extended cab SR5, I've got 5100s in the front with ome 885x's set at 0" in front with TC UCAs, and a 1.5in. AAL in back. I recently did a bad wheel bearing and after going to get an alignment the guy tells me the rear alignment cam bolt was broken on the passenger and needed to be replaced... So I decided I'd have them install a new alignment bolt and cam... They ended up putting on a whole new lower control arm on the passenger side with the new moog bushings and bolts "passenger side only here"... Anyways after all said and done they go to align it and can't get the caster below 3.4 on the passenger side and the driver side is at 2.7. My question is, what could be screwing with lowering my passenger side caster? Really frustrated here, the truck bump steers like crazy, and pulls left.... Any advice or recommendations would be greatly appreciated!!!
  8. Mar 16, 2015 at 6:04 PM
    BBBsti LTD
    Irvine, CA
    What about the rear numbers? Are those within specs???
