Alignment or tire balance?
Discussion in 'Arizona' started by anasseef, May 12, 2012.
  1. May 12, 2012 at 11:08 PM
    anasseef
    anasseef [OP] Active Member
    Chandler AZ
    Tacoma TRD Off Road
    STAGE 1 COILOVER SYSTEM
    My tires are wearing uneven and my truck shakes at about 65-70. I have read this can be one of many different things from a camber issue to an alignment or tire balance. Is this something I just have to tackle one area at a time until I get it right or is there one issue that affects tacomas as a whole?
    Also can this be a side effect of a bad lift install?
  2. May 12, 2012 at 11:25 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    '18 T4R & '06 F250
    6" lift 40s
    Shakes are normally a balancing issue, but if the alignment is way off it can shake and also feel "squirrelly"
    how so? are tires inflated properly?
    And this could very well be from a crappy install of a lift.
  3. May 12, 2012 at 11:25 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    '18 T4R & '06 F250
    6" lift 40s
    And BTW, pics would help a ton for diagnosing this :worthless:
  4. May 12, 2012 at 11:37 PM
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    the tires are wearing unevenly could be just over/under inflated tires or a mis alignment issue. After after lifting or lowering a vehicle the alignment angles change which could also cause the shaking youre feeling. The shaking could also be from bad balancing. Start by checking air pressure, then the balance of the tires and then the alignment.
  5. May 12, 2012 at 11:45 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    i'd spend the money to get it all aligned/balanced
  6. May 12, 2012 at 11:49 PM
    anasseef
    Chandler AZ
    Tacoma TRD Off Road
    Squirrelly is exactly what happens. I tried to explain that to the guy at the dealership and he tried to talk me out of using that phrase for some reason.
    Tires are inflated correctly, I'm a little OCD with things like that.
  7. May 12, 2012 at 11:51 PM
    anasseef
    Chandler AZ
    Tacoma TRD Off Road
    Good point, didn't think of posting any pics. I was just curious as to where to start with a diagnosis and begin to take on the issue.
  8. May 13, 2012 at 7:34 PM
    ocherp
    ocherp Well-Known Member
    Gilbert, AZ
    2016 V6 4X4
    SDHQ built
    Where's a good shop to go to? I need one bad too, alignment/balance and tires rotated.
  9. May 13, 2012 at 10:36 PM
    BMOC
    Paden
    Phoenix, AZ
    Network alignment in Gilbert.
    they're my favorite because they know what they're doing. :cool:
  10. May 14, 2012 at 10:24 AM
    Aw9d
    Aw9d That one guy
    x2
    I've been going there for, hell I can't even remember its been son long. But they are the only people I trust to do any suspension work.
  11. May 14, 2012 at 11:08 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Agree with the rest of the guys. Get an alignment, balance (maybe even road force) and rotation. I'll be doing this exact same thing once I get my new UCA's.... Which could be another issue for you.
  12. May 14, 2012 at 11:26 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    X3, I got my alignment at Network and they actually knew what a uniball is lol. Good guys there
  13. May 14, 2012 at 11:35 AM
    AZ4point0
    AZ4point0 Well-Known Member
    V
    Northern AZ
    Tacoma TRD Off Road
    Tacoma TRD Off Road, V6, S/C, Icon Stage 1, TRD Exhaust, AFE Intake
    make sure they reset the stability control after the alignment
    that helped out on my truck after wheels and tires install
    first shop didn't do it not even the dealership
    went to a different place and they fixed all shakes and squirrellies
  14. Jun 1, 2012 at 3:36 PM
    parkp81
    parkp81 Well-Known Member
    Fil
    Southern California
    Do you know how this is performed?
  15. Jun 1, 2012 at 6:12 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Yup agreed... get the tires rotated/balanced and road force tested first. If they check out good, verify the alignment. If that's good... time to start digging in more. Check for play in the front wheels (hubs, steering rack, tie rod ends, ect). Also inspect your carrier bearing on the driveshaft.
    Also, what kind of tires are you running? I always have some sort of vibration with my KM2's, but for a MT they're about as good as it gets. Even my old AT's did to an extent... just a price you pay for aggression.
  16. Jun 5, 2012 at 4:39 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Aftermarket rims might require hub spacer rings, too. Solved alot of vibration issues for folks on here.
