Alignment problems with bigger tires??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clawsonator88, Jun 10, 2015.
  1. Jun 10, 2015 at 4:00 AM
    clawsonator88
    clawsonator88 [OP] Member
    Alaska
    2012 TRD Tacoma V6
    First post but love TW and a complete amateur so be warned!
    For starters, I have a 2012 Tacoma with Nitto Trail Grapplers LT285/65R18 with lift.
    Ever since purchasing this truck used with 18,000mi on it, it has ALWAYS pulled hard to the left. I never noticed it before since I was so stoked with the truck. I recently got an alignment since I seemed to always have my arm locked at the 2 oclock position, or else it pulls immediately. I took it to my local Toyota dealer and they said the toe, camber were WAY off. ( will post spec report later) they were able to fix to suggested specs and thought I would be good. NOPE, still pulls hard to the left. The roads in Alaska are pretty bad with tons of ruts and grooves but im more concerned why im still having the pull.
    So here's my questions....
    1.) Should I ditch the bigger tires and go back to stock?
    2.) Will going back to stock tires and wheels have an issues the lift?
    3.) Recently got a flat, and the tire is hard to find in Anchorage. In fact no one had it in town and would have to order the $400 tire. LUCKILY the shop was able to patch it. Should I just go to stock tires for the sake of them being more available and less expensive?
    Thanks in advance! Just want a straight and true taco.
  2. Jun 10, 2015 at 5:14 AM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    clawsonator88[OP] likes this.
  3. Jun 10, 2015 at 5:23 AM
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    If your tires are cupped or worn unevenly from driving with a bad alignment for this long that could be the issue.
  4. Jun 10, 2015 at 5:28 AM
    clawsonator88
    Alaska
    2012 TRD Tacoma V6
    thanks I guess ill take it to a different shop that deals with way more off road trucks. Worth a shot. Will check sub forums for more help thanks
  5. Jun 10, 2015 at 5:29 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    I would bet your tires are worn unevenly from being out of camber and toe. That's why it's still pulling even after alignment.
    New tires will make the issue go away; rotating tires will help for now. Aggressive tread and larger tires tend to follow the grooves in the road more. 285s that aren't all jacked up from being out of alignment should still handle fine on a truck that is in alignment.
    I'd also check your tie rod ends for play.
    Next time it's out of alignment, take care of it right away.
    Shouldn't have any issues going back to stock.
  6. Jun 10, 2015 at 7:15 AM
    VandalTaco
    VandalTaco Well-Known Member
    Will
    Moscow/Idaho falls, Idaho
    07 DCSB TRD SPORT
    OME 887 lift, 16" XD addicts, 285 duratracs, leather seats, badass JL/Focal stereo
    Aftermarket Upper control arms would probably help. I've read in here that it is difficult to get a good alignment with a lift over 2.5 inches without some aftermarket UCAs...I would look into that. I just had my truck lifted and put on 285s. Toyota said it aligned just fine but it doesn't feel perfect. I'll be getting UCAs to fix this soon.
  7. Jun 10, 2015 at 7:29 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    if you are asking these questions then you don't require bigger tires, [like
    you aren't driving on corduroy roads prospecting new grounds or anything...]
    [if you were swamping and breaking trail stock size is not the way to go]
    so I guess stock tire sizes are the way to go.
    nitto tires are not balanced from factory as well as a michelin. you
    may want to go back to stock size and michelin tires to get the absolute best
    chance at a wheel and tire combo that has no imperfections or balance issues.
    then using this, have it balanced and aligned
  8. Jun 10, 2015 at 7:38 AM
    Pigpen
    Dan
    Northwest Montana
    I paid my dealer to do an alignment after I lifted. They said they would try to get my toe and camber to the 0 I asked for. They got it "in spec", which was nowhere near 0. Go to a small shop for alignment and ask for specific numbers. Your caster is not adjustable without special UCAs that are adjustable, but most aftermarket UCAs are designed to correct caster after lift. Narrower tires will probably help you. My truck wandered like crazy with 265 tires on backspaced rims. I sold the rims/ tires and put 255s on stock rims and there's no wander at all. 255s are slightly taller than your 285s, but much narrower. I do have a pull to the right, but it's an alignment issue.
