Alignment problems
Discussion in 'Suspension' started by o.cj92, Aug 19, 2012.
  1. Aug 19, 2012 at 10:24 PM
    o.cj92
    o.cj92 [OP] New Member
    Nederland, Tx
    2011 Tacoma Dbl Cab 4X4 TRD Sport
    I recently installed a leveling kit on my truck and soon after I began to experiemce alignment problems with the right/front wheel. The base of the tire angles inward quite a bit and I was wondering if anyone knew what might be the problem. I would like to try and fix the problem before I spend money on upgraded wheels/tires. Thanks guys
  2. Aug 19, 2012 at 10:31 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Did you get an alignment ?
  3. Aug 19, 2012 at 10:45 PM
    TacoTony
    TacoTony Well-Known Member
    tony
    san antonio
    single cab rado
    Maxtrac spindles
    U need an alignment whenever u lift or lower a vehicle, it sounds like the toe adjustment is out, camber is probably out too
  4. Aug 20, 2012 at 7:27 AM
    o.cj92
    Nederland, Tx
    yes, I had it aligned the same day that I installed the leveling kit. I had it re-aligned because it was still under tye "alignment warranty" from Firestone but the problem is still there.
  5. Aug 20, 2012 at 10:48 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Did you get an alignment spec sheet from them? What are your caster and camber angles?
  6. Aug 20, 2012 at 6:33 PM
    TacoTony
    tony
    san antonio
    single cab rado
    Maxtrac spindles
    How was your alignment before? If your tires were out and then u aligned it, you might have radial pull
  7. Aug 20, 2012 at 6:35 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Yea where is the alignment sheet they gave ya. Post it up.
  8. Aug 23, 2012 at 8:21 AM
    o.cj92
    Nederland, Tx
    problem fixed, went to have my truck re-aligned at a local shop and good as new.......turns out that my Modica Bros. sucks, thanks for your help guys
