Alignment Problems?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mootsman, Nov 14, 2009.
  1. Nov 14, 2009 at 6:00 AM
    Mootsman
    Mootsman [OP] Active Member
    Gunnison, Colorado
    02 Tacoma SR5
    3" Fabtech Lift
    Just wondering - This 02 Tacoma is my first lifted vehicle. I bought it used. It has a Fabtech kit, and is lifted about 3". I noticed a little uneven wear on the front end, so I'm about to get it aligned, although it seems to go very straight down the road - no big problems. I was just wondering if you have more alignment problems in general with a lift kit installed.
    Thanks
  2. Nov 14, 2009 at 6:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    When lifting, the geometry goes out. It can be brought back pretty close to OEM specs, but it will be near the max recomended adjustments. Many people get aftermarket UCA's (Upper Control Arms) that correct for these issues. Idealy, you want your Camber and Toe set as close to 0* as possible, if not right at 0*. You want the Caster between 2.2* to 2.9* or so.
  3. Nov 14, 2009 at 4:53 PM
    Mootsman
    Gunnison, Colorado
    02 Tacoma SR5
    3" Fabtech Lift
    Thanks, i think I will get it aligned next week and see how close they can get it.
