Alignment question regarding TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jed1894, Feb 10, 2011.
  1. Feb 10, 2011 at 7:07 AM
    jed1894
    jed1894 [OP] Active Member
    2011 Tacoma 4x4
    I'm getting ready for the leaf TSB and called to ask about the allignment issue (making sure they had all the parts in). The tech said that there may not be a need for alignment after TSB. This does not sound right because of the extra lift in the rear and according to the TSB an alignment comes with the deal. Hopefully, he is correct because the truck drives perfectly (alignment wise). Any info?
    thanks, jed
  2. Feb 10, 2011 at 7:28 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    On my 2010 the alignment was specified in the TSB. I don't have a copy of the TSB for the 2011 so I don't know for sure on that. I have a 2010 TRD Sport and it only got the leafs since I already had the sport shocks and they did the alignment.
  3. Feb 10, 2011 at 7:31 AM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    Same here. Service writer told me that an alignment was done after the rear springs were replaced. I'm thinking they have to do the alignment to make sure the front and rear wheels track correctly.
  4. Feb 10, 2011 at 7:44 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    As a check to make sure the tech didn't do something stupid. If you or I were swapping out our leaf packs, we wouldn't NEED an alignment, but it's a quick check to make sure nothing is out of line. Plus, it's part of the TSB so Toyota should provide the service as required by the bulletin.
  5. Feb 10, 2011 at 7:49 AM
    Natetroknot
    Natetroknot Def Leppard Sucks!
    Nate
    Dubuque, IA
    '11 Black Access Cab
    Billy's @ .85, 1.5 Progressive AAL, Leer 100xl, BFG KO2's
    It isn't possible to align the rear end of a solid axle vehicle: there is nothing to adjust.
  6. Feb 10, 2011 at 8:01 AM
    trdr6
    trdr6 Well-Known Member
    Clay
    Greensboro, NC
    '10 TRD Off-Road 4X4 Double Cab Magnetic Grey
    AFE Stage II Si CAI, Raptor Series Straight Chrome Step Bars
    Had mine done. No issues with alignment. Your only lifting the rear of a solid axle truck, the alignment shouldn't be affected at all as long as everything is assembled correctly in the rear. But if the TSB states an alignment check is to be done, I'd make sure they did it, people make mistakes.
  7. Feb 10, 2011 at 8:40 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    No, but you can chuck bad springs.
    Possible that there's a concern that changing the weight of the vehicle will move your front control arms down, which, should deflect your toe-in. Question is, has anyone ever had an adjustment made on this alignment check. AND when their springs finally settled, did they do it again?
    Or maybe they have adjustable castor..... :cool:
  8. Feb 10, 2011 at 9:16 AM
    kws129
    kws129 Well-Known Member
    PA
    TRD Off Road Double Cab
    You need to align the truck because in effect by raining the rear end up you are changing the caster in the front end of the vehicle. Now just the spring TSB "probably" wouldn't be enough to mees anything up. But if you try and drive a vehicle with the caster out of adjustment it either won't turn or it will dart across four lanes of traffic and hit a bus full of kindergarteners causing it to burst into flames etc, etc if you even breathe on the steering wheel
  9. Feb 10, 2011 at 9:24 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I have an 07 and they performed an allignment after the TSB was completed (that was 3 years ago).
    As you mentioned, there's a shift of weight (so to speak) and I'm sure it could change the caster or toe. As a precaution, Toyota includes the allignment??? But maybe....over the years, the allignments haven't resulted in many changes to the actual numbers. So - they could've stopped doing them to save money. That's just a guess....
    After 3 years with these springs/allingment - I haven't had an allignment since and I haven't noticed any differences. ????
  10. Feb 10, 2011 at 9:35 AM
    island808
    Jedediah
    hawaii
    Most people don't get alignments nearly as often as they should.. I notice a lot of bad tires on cars that are strictly alignment based. Even on my old tacoma, springs settled and wore the inside of my fronts off in a few months, granted it was a few months driving between texas ny and california and all points inbetween.
    If you can get a free alignment .. go for it.
  11. Feb 10, 2011 at 4:43 PM
    jed1894
    2011 Tacoma 4x4
    Thanks for all the replies.
  12. Feb 10, 2011 at 4:51 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    The rear gets lifted an inch-not enough to make a difference in the front end considering one inch over a great length. If the job is done correctly -no issues. I had the tsb done on my 2011. Tech who I know personaly told me that he did check the alignment just for the hell of it and it was perfect.
