alignment question with TC upper arms....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sincitytaco, Apr 11, 2009.
  1. Apr 11, 2009 at 3:14 PM
    sincitytaco
    sincitytaco [OP] Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    What is the most amount of caster we can run on these trucks and keep them handling well. I want more caster because my tires hits the rear part of the fender. I have cut the frame and welding in a plate, but I still rub a little on the fender now and I have cut all the plastic I can. I notice the wheel is closer to rear of the fender than the front and I know increasing the caster will move it forward so that i why I want to do this.
    How are people clearing 285s with TC upper arms, because the arms move the wheel back and make it rub?
  2. Apr 11, 2009 at 4:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Increaseing the caster will move the wheel rearwards. You need to have some caster taken out.
  3. Apr 11, 2009 at 11:10 PM
    P. Bauer
    P. Bauer Well-Known Member
    San Jose
    08 Tacoma 4x4 TRD Off-Road
    TRD S/C :: Intake Camburg SwayAway Magnaflow American Racing Donahoe Racing Wheelers OffRoad
    Hope you didn't install the TC UCA's on the wrong side, this would cause some issues for sure. Double check your installation.
  4. Apr 11, 2009 at 11:17 PM
    sincitytaco
    Las Vegas
    No because when you increase caster from the adjustments at the bottom. It moves the lower control arm forward.
    Moving the UCA rear ward increases caster and moving the lower one forward increases caster.
    That is why aftermarket UCA move the top of the spindle rearward, this is what causes the rubbing with larger tires on the cab mount and back part of fender.
  5. Apr 11, 2009 at 11:32 PM
    P. Bauer
    San Jose
    I understand what positive and negative caster is and the benefit of running aftermarket UCAs, I have the Camburg UCAs with Sway-A-Way 2.5 coilovers running 285/75-R16 BFGoorich All-Terrains. I had to remove the mud flap and trim the very bottom of the wheel well, but I don't have any rubbing on the frame, body or anything like you are describing. I did get an alignment done after isntalling the suspension and this helped tremendously with the way the truck drove on the street/highway.
    YMMV.
  6. Apr 11, 2009 at 11:59 PM
    sincitytaco
    Las Vegas
    I have done some reasearch on Toyotanation.com and have found that some people are running upwards of 4 degrees castor with UCAs to get the tire centered in the wheel well. Mine is set at about 3 and it is definately closer to the rear than the front. If I could center it, I would be GOLDEN.
  7. Apr 12, 2009 at 12:36 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    NO! If you add Caster it will move the wheel forward. (Due to the fact that the adjustment cams are located on the LCA's)
    But! You may increase the chance of Bump steer if you go too high.
    Try adding a bit more lift.
    If I remember correctly you have the ICON's???
    Order a ToyTec top plate spacer. That way you can increase (Tweak) the amount of lift you have to give you the clearance you need. Without over extending the Icons.
    Some people have this issue because of different reasons. i.e. tire size difference in brands, or they are not getting the full 3" of lift.
    When I had my 3" lift (ToyTec 885) I actually had 3.25" of lift.
    Just watch your CV boots. You can "cheat" by removing the outer clamp and pulling the boot out, so the fins don't rub. Put a drop of super glue so it doesn't slide back and clamp it secure.
  8. Apr 12, 2009 at 1:19 AM
    sincitytaco
    Las Vegas
    I did not know you could use the Toytec top plate spacers with coilovers. Makes sense that you could though. Are the bolts that come with ICON coilovers long enough to accomodate the spacers?
  9. Apr 12, 2009 at 2:00 AM
    toku58
    Mall Crawler!
    You may need longer bolts.
    I had custom spacers on my Fabtech CO's. Keeps the ride soft, rather than cranking them up.
  10. Apr 12, 2009 at 5:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your right, I was thinking in relation to adding UCA's. They add the caster by moveing the baljint location rearward, thus increaseing caster. Brain fart.
  11. Apr 12, 2009 at 10:40 AM
    sincitytaco
    Las Vegas
    Thanks, I already ordered a set from Toytec. The bolts will be easy to find once they come in. I will get the specs from ICON and find a set that is 1/4 longer. This will let me lower my coilovers down 2 turns or so. That will be great.
  12. Apr 12, 2009 at 12:50 PM
    P. Bauer
    San Jose
    Just ordered the 3/4" spacers from ToyTec to add to my Sway-A-Way front coilovers, I hate having them cranked so high and firm.
    We'll see how this works.
  13. Apr 12, 2009 at 1:02 PM
    sincitytaco
    Las Vegas
    3/4 inch don't you mean 1/4 inch. The top plate spacers are 1/4 inch, RIGHT!?
  14. Apr 12, 2009 at 1:12 PM
    sincitytaco
    Las Vegas
    I assume this is what you are talking about:
    I ordered the ones with out the bolts. If you have coilovers the bolts are unnessary because they are the wrong kind. You are going to have to hit up a hardware store and get bolts that are 1/4 inch longer than the ones you got.
    I this these are the same spacers as the 1/4 inch spacers, right? The ones that come with the bolts are $10 more.
    I have heard they only provide about 1/2 inch of lift, but either way I am happy. I don't want to have to sag my coilovers to far because I have the rear TSB and it rides pretty stiff with the 5100s. I wouln't want it to handle unevenly.
  15. Apr 12, 2009 at 1:17 PM
    toku58
    Mall Crawler!
    No! The 3/4" spacer is actually 1/2" thick spacer that comes with the longer studs.
    Call Doug to see if you can get a discount for just the spacer without the studs.
    That is the spacer that I was referring to.
    My spacer is 5/8" which gives me 1" of lift.
  16. Apr 12, 2009 at 1:18 PM
    sincitytaco
    Las Vegas
    WAIT!! What is the difference between this one:
    and these:
    one claims to give 1/2 of lift and the other claims 3/4 inch of lift. I thought they were the same. What is the difference?
  17. Apr 12, 2009 at 1:38 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Ive heard of people modifying the body mount to clear 285's
  18. Apr 12, 2009 at 1:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. You can notch out the BM and weld in a peice of steel to box it, and it will be fine.
  19. Apr 12, 2009 at 3:12 PM
    sincitytaco
    Las Vegas
    Gay, but true.
  20. Apr 12, 2009 at 3:59 PM
    P. Bauer
    San Jose
    http://toyteclifts.com/index.php?pag...mart&Itemid=53
    Don't need the studs, since I have the coilovers, I will call ToyTec tomorrow and see if they can send the spacers without them. I'm not trying to get a discount, but don't want them to send unnecessary parts.
    I'll post pics once installed.
