Alignment Question
Discussion in 'Suspension' started by gmata, May 18, 2013.
  1. May 18, 2013 at 9:38 AM
    gmata
    gmata [OP] Well-Known Member
    Gonzalo
    Tucson
    2002 TRD 4x4
    Hello guys,
    I have a quick question.
    I have a 2007 4x4 V6 DCab Tacoma with a Pro Comp 3 inch lift.
    I was having some alignment problems and I decided to get after market UCA.
    I bought the Light Racing UCA and installed them. I took my truck to get it aligned using a computer and this are the numbers i got.
    Camber Left Right
    0°31' 0°10'
    Total 0°21'
    Caster 0°33' 1°16'
    Total -0°43'
    I am little concerned with the Caster since the specs are 1.3 to 2.8 and I have .33 at the left wheel.
    However the technician assured me that this settings would not worn my tires and the truck is actually driving straight with this settings.
    Should I be concerned about that or should i leave it like that.
    Thanks
  2. May 18, 2013 at 9:55 AM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    Caster in and of itself does not cause tire wear. Caster affects toe as the more caster a vehicle has, the more the wheels tend to toe in. For this reason insufficient or excess caster can cause toe wear, even though toe is set to specification.
    So it just depends on other factors. Someone correct me if I'm wrong here.
  3. May 18, 2013 at 10:00 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    I agree. I wouldn't worry about it but I would keep an eye on tire wear.
  4. May 19, 2013 at 6:44 AM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    You got the LR UCA's to get your alignment more in spec after the lift, as they are adjustable. Bring it back and get it within the factory ranges. Preferably higher caster, it will make the truck less jumpy while on the road.
  5. May 19, 2013 at 7:07 AM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    Yea that tech doesn't know what he is doing. I set these trucks with lifts and bigger more aggressive tires caster in the 3-3.5 range. He should be able to get the camber to 0 degrees. I'm; sure that truck likes to wander all over the road. I know it wants to pull left some. The numbers say it will. I would check all your tires pressures too to make sure he didn't set them to make it act like it was driving ok.
  6. May 28, 2013 at 1:41 PM
    Dano.oh
    Dano.oh Member
    Dan
    Denver
    2013 TRD OR DC 6 spd.
    3" Toytec Ultimate lift, Light Racing UCAs.
    I had an alignment done on my 2013 Taco after installing a Toytec Ultimate lift but am having some "bump steer" problems. I was originally looking into a steering stabilizer but after reading a few posts on the subject, it seems like that is not really a good solution nor is it really my problem.
    The alignment was done to factory specs, (see image) but it seems like with a lift I want to go:
    0* camber
    0* toe
    2.6-2.8* caster
    Do the numbers above seem accurate? Im assuming these numbers are for left and right tires individually and not cross camber/caster right?
    I now have 285/75R16 tires installed. When the alignment was done the tires were stock.
    Any insight you may have is helpful, im getting a little annoyed with the "loose" and "jumpy" steering.
    Thanks
  7. May 28, 2013 at 3:16 PM
    ntilehman
    Seth
    Charlotte, NC
    I would have your caster set higher, more in the 3.0 range. If you lift it you still want close to factory settings. I personally like more caster. Your camber is a little positive and will wear the outer shoulders of the tires. There should not be any bump steer.
  8. May 31, 2013 at 1:52 PM
    Dano.oh
    Dano.oh Member
    Dan
    Denver
    *Update*
    Had my alignment re-done today. 0* camber, 0* toe, 3.0* caster. The taco handles like a champ! The loose feeling in the steering is completely gone and the "bump steer" problem I had is under control. Feels like factory now.
