Alignment Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dpi, Jul 15, 2015.
  1. Jul 15, 2015 at 9:22 AM
    dpi
    dpi [OP] Well-Known Member
    Dan
    Tulsa, OK
    AFE Stage 2 SI CAI Banks 3" Mandrel bend Cat Back dpi Rock Sliders
    The current configuration is bilstien 5100 set at 1.75".
    I am adding a winch with synthetic rope and a U.S. Off-road mount.
    My question is, since the extra weight will make the front droop,will I need an alignment if I move to the 2.5" notch on the shock?
  2. Jul 15, 2015 at 11:23 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yes, any changes to rideheight in the front will need an alignment. That stated, at 1.75 setting, the winch and rope wont reduce ride height much at all and wont need and alignment. But moving up .75in will need an alignment and likely UCA's
  3. Jul 15, 2015 at 2:35 PM
    dpi
    Dan
    Tulsa, OK
    Thanks for the reply. That's what I was thinking. I would like to go up an inch, but if I do, its UCAs and probably 2885s instead of the stock springs.
  4. Jul 15, 2015 at 7:37 PM
    GroupW
    GroupW Well-Known Member
    Mark
    Arizona
    Red TX
    3 inch lift with Toytec Boss and All Pro UCA's up front. AP expedition leafs with Bilstien 5100 shocks in the back. 255/85/16 Cooper S/T Max tires. All Pro skids, rear bumper and sliders, Hidden winch mount with XRC 8000 winch. Dual Optima batteries with IBS combiner/isolator and solar. CMC. Auto sliding rear window mod, hidden CB, CVJ axles and plenty of other little mods.
