alignment question
Discussion in 'Wheels & Tires' started by taco man31, Oct 26, 2009.
  1. Oct 26, 2009 at 9:55 AM
    taco man31
    taco man31 [OP] Well-Known Member
    hey guys just two quick question,
    1. If i were to change just the rim but keep the tire size the same, do i need to get an alignment?
    2. If i change just the tire size but keep the rim size the same, do i need an alignment?
  2. Oct 26, 2009 at 9:59 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    In both instances it would be a good idea to get an alignment. Even though you are keeping the same tire size so to speak, different manufactures of tires produce different total circumferences for the same 'size' tire. The amount can be small, but enough to cause an irregular wear pattern.
    In any event that you change tire size you should have the vehicle aligned.
