Alignment question
Discussion in 'Suspension' started by tweeter1148, Dec 30, 2019.
  1. Dec 30, 2019 at 5:34 AM
    tweeter1148
    tweeter1148 [OP] Well-Known Member
    Brandon
    Fort Worth, TX
    19 DBL CAB SHORT BED TRD OFF ROAD
    I am installing 6112/5160 Bilsteins today. The 6112’s are on the 4/5 notch. I am adding the 2” AAL and keeping the overload spring in because I tow a boat. For now I am keeping the stock upper control arms. Can anyone help me out with what my alignment numbers should be? Off the hip i was thinking as close to 0 as possible and 2-3 on caster?
    thanks
    BB
  2. Jan 2, 2020 at 8:24 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Personally I like 0 toe, 0 camber. Caster 3 or higher. Personally on caster I run 4 degrees.
  3. Jan 3, 2020 at 6:24 AM
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    With stock UCA you won't be able to adj camber, max out your lowers for max caster you'll probably be @ +/-2.5* then set you toe to spec
