Alignment Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yamasaki, May 11, 2010.
  1. May 11, 2010 at 3:12 PM
    Yamasaki
    Yamasaki [OP] Yamaha + Kawasaki!
    Denver, CO
    2003 Tacoma Limited TRD 4x4
    Have 2003 Taco. Just had the ball joint recall done and got a full alignment with it. Alignment came back all green and everything is in check. My tires however are wearing funny. Inside of tire worn down more. Now I am wondering if this issue was fixed when they did the alignment (only been 300 miles since alignemnet. Tires have been on for about 3k miles) but what I also wanted to know is could there be another issue causing my tires to wear funny even if the alignement is all good? Camber/Caster apparently was all within specs.
    Thanks
    No lift/all stock truck.
  2. May 11, 2010 at 6:42 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Sounds exactly what my truck did after the recall. The insides of my tires wore to nothing real fast. I put on 15,000 since the recall work and now got a new alignment. It wasn't too far off, but enough to eat my tires. I guess once I get new tires I will know if the problem is fixed now. Still on original tires from 7 years ago...:eek:
    Might want to think about a new alignment. Can't trust everyone.
  3. May 12, 2010 at 7:13 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    I am the opposite...the outside of my tires are worn right down...insides have lots o meat left on them...
