Alignment questions after adding 3” readylift leveling kit 33”
Discussion in '3rd Gen. Tacomas (2016-2023)' started by The Riddler, Jan 22, 2018.
  1. Jan 22, 2018 at 3:16 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Just a question that is all.
  2. Jan 22, 2018 at 3:20 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Thanks guys I appreciate it! Lift install normally runs us about 8 hours, give or take for front and rear, and have done multiple Tacomas, including a 3rd gen that also got Ride Right airbags installed in the rear.
  3. Jan 22, 2018 at 3:21 PM
    DrFunker
    DrFunker Well-Known Member
    3rd gen. Was that recently? o_O
    Unchained 5150 likes this.
  4. Jan 22, 2018 at 3:21 PM
    The Riddler
    The Riddler [OP] Well-Known Member
    Boston, MA
    17 Sport
    I think I’m done with the lift experiment and the bigger tires...Going back to stock. I guess
    I made mistakes. I put the kit on I’ll take it off. I’ll lose the cost of the kit and my time. It is what it is. I tried to read the forums and suggestions and it’s my own fault.
    Oh well. Thanks again for your honesty guys.
  5. Jan 22, 2018 at 3:24 PM
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
    Just because 3rd gens are an inch higher than a 2nd, doesn’t make it a 4 inch lift
    Hobbs likes this.
  6. Jan 22, 2018 at 3:25 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Understood and that is why there was a ? at the end of the question. Good Luck OP I'll see myself out now.
  7. Jan 22, 2018 at 3:26 PM
    tacobell007
    Drew
    Western MA
    Last summer in August at some point if I remember right
  8. Jan 22, 2018 at 3:28 PM
    DrFunker
    Must have been nice to work on a "clean" truck. :D
    tacobell007[QUOTED] likes this.
  9. Jan 22, 2018 at 3:32 PM
    tacobell007
    Drew
    Western MA
    We put in a Toytec Boss kit, new leaf packs and 2.5 non-resi coilovers up front, which we had to adjust to proper ride height. The lift and ECGS bushing by itself took us 5 hours to do, then he said if we wanted to make some more money we could put the airbags in for him. Which we proceeded to do after a trip to the hardware store and we ended up at a total of 8 hours
    DrFunker[QUOTED] likes this.
  10. Jan 22, 2018 at 3:48 PM
    Big Dustin
    Big Dustin Well-Known Member
    Dustin
    Denver, Colorado
    '17 Tacoma DCSB SR 4x4
    5100's all around, OME 887 with 1/4" spacer, icon 3 leaf aal. 255/75/17 BFG KM's on 4runner pro's. Rigid led pods. Debadged and tinted.
    Look man, don't let the opinions of people on here deter you from what you want out of your truck. I have run every kind of lift kit out there, from torsion keys, to hockey pucks, to drop bracket lifts, spring replacements all the way up to extended travel coilovers. Every kit on the market has pros and cons, if they didn't, there wouldn't be thousands of then out there. If the pucks work for your intended use, enjoy the cheap lift and good looks. If you're going to be doing overland, prerunning, rock crawling etc, you will break stuff. For probably 95% of truck owners out there, a spacer lift will give them nothing but joy.
    Onto the heartburn over your alignment. Your lifting method did not cause the low caster numbers, the overall height did. I am running a forum favorite lift (5100 with 887 springs) which netted around 2.5" of lift and my caster is also less than one. The next component needed to fix your alignment is UCA's. They are not required, but it makes the driveability of the truck a lot better. I am still running my stock UCA's, as I was hoping I could avoid the extra expenses up front. I've put 2,000+ miles on my truck with them. Yes I have low caster, yes I have some bump steer, it's certainly not the end of the world. I'm not beating the fuck out of my truck like most people seem to think is a requirement once you lift it.
    I say, run the truck as it is and see if you like it. If you live the look/height, but want to fix your alignment, then order up some UCA's. If you're sick of throwing money at the truck, then you can remove the lift, but you'll have to pay for another alignment just to go back to stock, which kinda sucks. Hope that helps...
  11. Jan 22, 2018 at 4:07 PM
    The Riddler
    Boston, MA
    17 Sport
    Thanks BD. I really appreciate that insight. I can read through the lines and see that Leveling kits or hockey pucks as I am learning now, are not favored by some and some like it,. Truth be told, I just want some extra clearance and like the looks. The only 4 wheeling you will see me at is a beach and the more plovers and turtles we get? The less beach access we have. I can see where the 5100 shock crowd is coming from. Maybe that's a route I will take. For now, I'm going to go into a hold pattern, just called up the tire joint and cancelled that appointment for tomorrow and come up with another plan. Thanks again man.
  12. Jan 22, 2018 at 4:30 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Like I said when you decide to change it up or do whatever you want to do the Boys in Western Mass will hook you up nicely. @tacobell007 and his buddy Levi are amazing.
    tacobell007 likes this.
  13. Jan 22, 2018 at 4:33 PM
    The Riddler
    Boston, MA
    17 Sport
    I really appreciate that offer but no thank you.
    Hobbs and EatSleepTacos like this.
  14. Jan 22, 2018 at 4:49 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    @The Riddler at the very least talk to Marie over @HeadStrong Off-Road, I purchased my kit from them. I have heard wonderful things about their customer service, really quite knowledgeable. Took me 18 months of research before deciding on what I would need and how much. Took about 5k for rims/tires/lift/ecgs bushing. I made a few mistakes along the way but nothing serious. The ride and look is exactly what I need "for now". If you put aside all the bs here, most people are willing to steer you in the right direction. Spacers, Blocks and Hocky Pucks tend to provide a very harsh ride, if you can't enjoy driving your truck, then you won't drive it as much.
  15. Jan 22, 2018 at 5:19 PM
    #35
    The Riddler
    Boston, MA
    17 Sport
    I'm good thanks. Thank you.
  16. Jan 22, 2018 at 5:24 PM
    #36
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    :eek: 8 hours?! Shouldn't take any longer than 4 unless something goes wrong. I've installed lifts on 6-7 tacomas now and none have taken that long. That's with doing everything right and torquing it all to spec.
  17. Jan 22, 2018 at 5:57 PM
    #37
    tacobell007
    Drew
    Western MA
    That's an hour lunch break, UCA's, front setup, ECGS bushing and new seal, top off front diff, rear setup, shims or carrier drop if wanted/needed, test drive, tweaks, and BSing. I've had trucks that took awhile to tweak in trying to get the pinion and driveshaft angles right.
  18. Jan 22, 2018 at 5:58 PM
    #38
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ahhh, yep I could see it taking that long with the ECGS bushing in there, and the other couple minor things. I always did those things after the fact to see if they were needed. :thumbsup:
  19. Jan 22, 2018 at 6:00 PM
    #39
    tacobell007
    Drew
    Western MA
    Plus as @Unchained 5150 stated, we are meticulous about care for the person's vehicle and torque specs for certain things. Some people want changes made along the way or after the lift is complete, it really all depends
  20. Jan 22, 2018 at 6:00 PM
    #40
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Took about that amount of time when they boys did mine including the ECGS Bearing, lift front and rear, plus new UCA's and shooting the shit as well
