Alignment Reading
Discussion in 'Suspension' started by rumpot, Dec 6, 2013.
  1. Dec 6, 2013 at 8:57 PM
    rumpot
    rumpot [OP] Member
  2. Dec 7, 2013 at 9:57 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    If you want your caster to be in spec, yes. Technically you'll be okay with your caster now, just be prepared for a wobbly steering wheel a highways speeds.
  3. Dec 7, 2013 at 2:01 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors
    Looks like all they adjusted was the front toe.
    Castor and camber are same delivered as what you brought it in with.
    And I always wonder how on a straight rear axle vehicle they can have amber and toe on the back.
    I would be curious of the shops work quality.
    PK
  4. Dec 9, 2013 at 1:21 PM
    rumpot
    rumpot [OP] Member
    Thanks for the input.
    I went ahead and got the LR UCAs
  5. Dec 9, 2013 at 5:46 PM
    YotaDan
    YotaDan Dan Vendor
    Dan
    Oregon
    That Caster is horrible. Needs to be at a minimum 1.3 degrees positive on both sides. Make them re-do it.
  6. Dec 10, 2013 at 1:34 AM
    PMK
    Florida
    10 DCLB TRD Sport
    That was my point, it appears to me the alignment shop did not even try to align it. There was no change in the castor or camber before or after aligned.
    The shop did the easiest thing and cranked the tie rods for 1 minute and brought the toe in correct.
    Basically the alignment was a total rip off. The truck may not even need new upper arms, though they probably won't hurt.
    PK
  7. Dec 10, 2013 at 6:49 PM
    rumpot
    rumpot [OP] Member
    Thanks for the feedback.
    They said that the adjustments were maxed out and could not be changed. They also mentioned that the ball joints are dry/ loose.
    They are putting on the new UCAs Friday so I will use this thread and the other alignment threads here to see if it all adds up.
    I have heard that this is a reputable place and used to do the lifts for Toyota of Carlsbad.
    My truck does have 124k so it really doesn't surprise me.
    Regards
    Eric
  8. Dec 12, 2013 at 1:30 PM
    SmogSUX
    SmogSUX No Money. No Love.
    Sacramento
    96 Tacoma Manual 2.7L 4x4
    Wheelers 5-Pack w/ AAL, ToyTec 1" Shackles, 10" 5125's, 5100's w/ ToyTech Springs, Braided Steel Brake Lines, AFE Filter, BAMF Sliders
    For a lifted Taco that's normal. The shop that did my alignment said they couldn't do anything about the Caster. Eventually I'll get some UCA's =/
  9. Dec 14, 2013 at 6:31 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2001 TRD Off-road Prerunner V6
    Icons, Konig Countersteers, BFG A/T's
    Can anyone give any insight about my alignment numbers? I'm just a little concerned about my right side caster...
    Camber: L: -0.61 R: 0.07
    Caster: L: 0.15 R: 1.35
    Toe: L: 0.10 R: 0.10
    These numbers are after I installed my Icons today set to 2"
  10. Dec 15, 2013 at 4:18 PM
    rumpot
    rumpot [OP] Member
    I have now noticed a weird noise from the front left traveling at 45 through 55mph, and no sounds above or below that speed range. It wasn't there before but after the lift, could the alignment shown above cause this?
    Regards
    Eric
  11. Dec 16, 2013 at 4:32 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    It could be the front differential bearing. There's a small needle bearing assy on your driverside, where the half axle slips into the front diff. With a lift, that bearing assembly takes a shit, and starts whirring/pulsing/vibrating.
    East coast gear supply sells a bushing to replace the bearing, and kill that noise.
  12. Dec 16, 2013 at 4:47 PM
    rumpot
    rumpot [OP] Member
    Thanks I'll take a look at that. For now they are replacing the axel as it is leaking so I hope that is it!
    Regards
    Eric
  13. Dec 16, 2013 at 4:50 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    ^Yea a leaking CV joint can cause the noise too - contaminants getting in.
  14. Dec 16, 2013 at 4:52 PM
    rumpot
    rumpot [OP] Member
    Final after arms
  15. Dec 16, 2013 at 4:53 PM
    KenLyns
    Belly of the Beast
    ^I'm surprised the UCAs did so little, but at least caster and camber are both in tolerance now.
    Right side caster is good: positive caster value means the steering axis is leaning back, which enhances the steering self-centering characteristic.
    Left side caster is bad. Judging by the camber value, there is probably more room for adjustment in the lower control arm cams.
  16. Dec 17, 2013 at 1:47 PM
    Fahrenheit
    Fahrenheit Rubberhead
    Garth
    NS
    13 MGM DCLB TRD Sport
    OME 3" kit w/ Dakars Pelfreybilt Steel bumper/ IFS HomerTaco Ghost Raptor grill TRD Beadlock w/ 255/85/16 BFG M/T
    I JUST (no really, JUST!) got home from picking up my truck after having an OME 3" kit w/ Dakars, LR UCAs, OCTaco brake lines and BFG 265/70/17 installed, my alignment numbers are like night and day from OEM to OME. The shop did a phenominal job!! The Caster after the alignment seems high, but from reading on here it will benefit me when I put on 255/85/16, or have I misunderstood?
