Alignment setpoints?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jrotts, Oct 1, 2010.
  1. Oct 1, 2010 at 7:50 AM
    jrotts
    jrotts [OP] Member
    2008 Tacoma Double cab 4X4 TRD Off Road
    Leveling kit, bug shield, spray-in bed liner
    I will soon be replacing my upper control arms with Light racing control arms to correct the poor control of my truck and feathering of my tires. So I can be very specific to the alignment shop can someone give me a solid recommendation on the alignment setpoints? My truck has a 3" lift with 265/75-16 off-road tires with factory rims. My truck is a 2008 4-door TRD off road edition. No other mods to the suspension other than the 3" lift. thanks!
  2. Oct 1, 2010 at 7:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Toe: 0* (if not precisley 0*, it should have + toe out but not to exceed .05*)
    Camber: 0*
    Caster: between 2.3* and 3.1*
  3. Oct 1, 2010 at 3:39 PM
    85yote09taco
    85yote09taco Well-Known Member
    Eric
    York, PA
    Tacoma TRD OR
    3'' OME lift, TRD CAI, Built Right UCAs, 285 Goodyear DURATRACS, black steelies, Fog light anytime, DTRL, Alternating turn signal, Diff breather relocated, Carrier bearing drop, Weathertechs, Bestop, Extended SS brake lines, CBI Sliders w/kickout, Cab mount chop, Total Chaos LCA skids, All Pro skids, Satoshi(HomerTaco), Bruteforcefab ''HC'' rear bumper, Bruteforce Hybrid front bumper
    Ok not to steal the thread but what if the caster exceeds 3.1*? because when I got my alignment done I was at 3.2* and ended up bumping it up another 1.0* so I didn't rub so bad on the fender closest to the doors
  4. Oct 1, 2010 at 5:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its not a bad thing. The wheel may sit further back in the wheel well (asuming you are running aftermarket UCAs).
