Alignment shop made pull worse. Any better shops in OC?
Discussion in 'Southern California' started by DNG, Dec 4, 2011.
  1. Dec 4, 2011 at 9:44 PM
    DNG
    DNG [OP] Well-Known Member
    Orange County, CA
    White 01 DC PreRunner
    After reading fairly good reviews on yelp, I went to 714 Tires to get my alignment done. All they did was fix my toe, but couldn't do anything about my camber and caster, which was causing a pull.
    I've read about the firestone lifetime deal, but I'm not sure if I trust them working on a lifted truck.
    Can anyone recommend a shop that does a good alignment and can work with lifted trucks? I also would rather not pay $100+ on an alignment.
  2. Dec 4, 2011 at 10:09 PM
    DNG
    Orange County, CA
    Thanks. Do you know how much they charge?
  3. Dec 5, 2011 at 6:41 AM
    vitang
    vitang Well-Known Member
    diamond bar
    07 TRD Sport 4wd
    Engage Front Long Travel, Giant Rear Long Travel, KR Fab rear bumper, tire gate and Jerry Can cage.
    B&D alignment in Whittier does a good job.
  4. Dec 5, 2011 at 2:03 PM
    dtaco06
    dtaco06 Thread Squatter
    Danny
    Orange County
    06 BSP AC PR / 07 4Runner
    If you don't mind the drive but want it done right, Simpson Frame and Alignment in Hollywood do great work. Unfortunately it's a bit of a trek from the OC though.
  5. Dec 5, 2011 at 6:53 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Did they give you a reason for not being able to make the adjustments? It seems to me there are bigger issues here than the shop doing the work.
  6. Dec 5, 2011 at 7:11 PM
    Sabre
    Sabre Well-Known Member
    Kyle
    Astoria, OR
    2009 DC 4x4
    Icon 2.5 coilovers, color match grill, DDM tuning 5k fogs, Retrofit Headlights, lower valence painted
    go to just tires on lincoln and knott over by knotts berry farm i think and ask for ben he did my truck and rc freaks and alignment of offroad vehicles is his specialty and it comes with a 6 month or 6,000 miles warranty so u can get it aligned as often as you like for 90 bucks not a bad deal
  7. Dec 9, 2011 at 10:34 PM
    rcfreak201
    rcfreak201 Well-Known Member
    yeah buddy! best place ive gone to so far
  8. Dec 9, 2011 at 11:15 PM
    Manwithoutaplan
    ID
    I know it is not in OC but. tucker tire in azusa will realignment in 90 days if it is pulling to the right or left.
  9. Dec 12, 2011 at 8:12 PM
    DNG
    Orange County, CA
    All they said is that the camber adjustment were "maxxed out". Whatever that means...:confused: He also said it could be because of my lift. My inner tie rod needs to be replaced, so I wonder if that could be causing some issues.
  10. Dec 12, 2011 at 8:12 PM
    DNG
    Orange County, CA
    I'll check this place out. Thanks
