Alignment Spec Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aubi1414, Sep 14, 2015.
  1. Sep 14, 2015 at 1:50 PM
    aubi1414
    aubi1414 [OP] War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Here are the specs before and after my buddies 05 Tacoma Prerunner alignment. He has a 3" lift in the front and rear. Not that the rear matters and the pdf is below. I typed in the new numbers as it didn't scan in very well. Sorry about that.
    What should these numbers be closer too if at all?
    The left side is .08 not .8 sorry about that. Let me know if yall can't open the pdf
  2. Sep 15, 2015 at 1:55 PM
    aubi1414
    Justin
    Pensacola, FL
  3. Sep 16, 2015 at 10:35 AM
    aubi1414
    Justin
    Pensacola, FL
    nobody?
  4. Sep 16, 2015 at 11:29 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Numbers look good to me.
    over 2* of caster, a smidge of neg camber, and a smidge of toe. Should provide a nice stable truck.
  5. Sep 16, 2015 at 11:34 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Agree, look good. with a 3" lift, I have read to try to get as close to zero on camber and toe, and 2.5-3.0 on caster. Is he on stock UCAs?
    Mine below, with Light Racing UCAs
  6. Sep 16, 2015 at 11:50 AM
    aubi1414
    Justin
    Pensacola, FL
    He has LR UCA's installed
    JimboAnz likes this.
  7. Sep 16, 2015 at 12:59 PM
    nd4spdbh
    SoCal
    yeah hes good.
    A lil neg camber like that will make tire wear even so you dont wear the outside of the tire quicker than the inside due to turning.
    Black Taco likes this.
