Alignment specs for 3 inch lift with OEM UCA
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CHarrison32, Oct 23, 2016.
  1. Oct 23, 2016 at 11:26 AM
    CHarrison32
    CHarrison32 [OP] Well-Known Member
    Cody
    West Virginia
    2011 AC 4x4
    Bilstein 5100 all the way around, wheelers 3-leaf progressive AAL, Camburg Ball-joint UCAs, SCS SR8, BFG KO2 20% tint, WeatherTech floor mats, Tacoma bed mat, tonneau cover
    I currently am running a 3 inch lift on my 07 RC and I still have OEM UCA and my alignment isn't the best and I was wondering if people could throw some numbers out there to what they are running with 3 inch lift and stock UCA. I am in the market for LR UCA but that will be a few months and I was going to go ahead and get an alignment to keep my tires from wearing poorly.
    Thanks,
    Cody
  2. Oct 23, 2016 at 1:28 PM
    jibski
    jibski Well-Known Member
    Josh
    Arvada, CO
    2009 Silver 2.7 AC 4X4
    If I recall correctly, at 2" lift with stock uca I was around .7 camber and .9 caster. I didn't think it rode that bad, even on highway. But I have since gotten LRs and am all dialed in.
  3. Oct 23, 2016 at 1:32 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    You want way more caster than than. I'mAround 3.0-3.5 caster, -.4 camber, and 0 toe
  4. Oct 23, 2016 at 1:33 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Good luck on OEM arms
  5. Oct 23, 2016 at 1:39 PM
    Aussiek2000
    2016 Offroad AC
    For some reason I read it as LR UCA, not OEM. oops
  6. Oct 23, 2016 at 1:39 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Beat me to it
    Aussiek2000 likes this.
  7. Oct 23, 2016 at 1:41 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    You're not crazy
    Aussiek2000[QUOTED] likes this.
  8. Oct 23, 2016 at 2:05 PM
    CHarrison32
    Cody
    West Virginia
    2011 AC 4x4
    I'm not sure what number I have right now. But I think it may be close to this. I'll tell the technician I want both camber and caster around .7-1 and as for toe around 0.
  9. Oct 23, 2016 at 5:33 PM
    jibski
    Josh
    Arvada, CO
    That'll probably be about the best you can do on oem arms. Most people will tell you ideally you want caster at 2-2.5+. But on the oem arms you hit a point in adjustment where you have to sacrifice camber (add positive camber in my case) to get more caster. As I mentioned, caster at 1 didn't bother me, but I also only ran it that way for a couple months before getting the LRs. Sitting at 3.3 caster now.
  10. Oct 23, 2016 at 5:36 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You want around 3,0,0
    You just won't get it
  11. Oct 23, 2016 at 5:37 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Your toe is incorrect for a rear wheel drive vehicle. You should have a bit of toe in to compensate for steer ahead which causes the front wheels to spread open when being pushed by a rear wheel drive. With toe at 0 you are scrubbing your tires when rolling forward and it will cause cupping.
  12. Oct 23, 2016 at 5:38 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    good luck.... seriously do yourself a favor, dont buy your starbucks lattes for a week and get some spc UCA's cus at 3 inches, you need ucas BADLY.
    Ideal specs IMO are around 3* of caster (up to 3.5 is OK for better tracking but steering will be heavier) .1* of toe in per side, and -0.2 to -0.4* of camber (negative meaning top of the tire in compared to the bottom looking straight on) This will keep the tires wearing evenly from inside to outside as the tires roll under during turns wearing the outside more than the inside during turning.
  13. Oct 23, 2016 at 5:49 PM
    Aussiek2000
    2016 Offroad AC
    I'm not worried about it. On 5th set of tires in a year
  14. Oct 23, 2016 at 6:36 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    :facepalm:...well for anyone else that cares about a proper alignment on a truck make sure they set your toe to OE specs or approx 1/8" of toe.
  15. Oct 24, 2016 at 4:54 AM
    CHarrison32
    Cody
    West Virginia
    2011 AC 4x4
    Well I would but I don't drink Starbucks or coffee in general. And considering I'm in college with no source of income there isn't much else I can do until I can get an internship.
    Believe me I would've already had them, my truck is a pain in the ass to drive. Having to constantly work to keep it straight.
    And btw does anyone know if LR UCA are longer than stock UCA because I'm about 1/4 inch from rubbing my UCA with my tire and I need to know if wheeler spacers are going to be needed or if I can just squeak by.
  16. Oct 24, 2016 at 8:18 AM
    nd4spdbh
    SoCal
    I dont think they are going to be any longer. I would recommend when you get them put the ball joint in the middle (D i think) caster position for an extra 2* of caster. Then slide the ball ALLL the way out to the outermost position away from the centerline of the frame.
    This will do two things. 1. get you more clearance for your 285's and 2. if you have to dissassemble / or somehow the ball joint gets moved (hard hit or something) you know where to put it back to to have alignment proper.
    I can get a pic or two of my SPC ucas with my 265's if you wish.
  17. Oct 24, 2016 at 9:07 AM
    jibski
    Josh
    Arvada, CO
    I was thinking about pushing my upper ball joint all the way out on my LRs. Were you able to get camber at 0 doing this? I'm just wondering if the LCAs have enough adjustability to accomplish that.
  18. Oct 24, 2016 at 9:22 AM
    tranandya
    tranandya Well-Known Member
    Andy
    Orange County
    07 DCLB TRD SPORT
    5100 885x LR UCA 1.5AAL FIRESTONE RIDE-RITE w/DAYSTAR CRADLEs
    You want 3,0,0
  19. Oct 24, 2016 at 9:30 AM
    OZ-T
    Peter North
    British Columbia
    Yeah my bad , fat fingers , no glasses
    I'll edit my post so there's no confusion
  20. Oct 24, 2016 at 9:52 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    0 toe is not correct
