Alignment Specs (heeelp!)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zandroid, May 16, 2017.
  1. Aug 4, 2018 at 4:14 PM
    #61
    Slvr14tacoma
    Slvr14tacoma Well-Known Member
    Mid travel
    Gotta ask im a 2nd gen but need an alignment bad. 255/85/16 on 16x8.5 4.5” backspaced wheels. Should i ask for the 0 toe 0 camber 2.5+ caster?
  2. Aug 4, 2018 at 4:35 PM
    #62
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What was your original wheel and tire size?
  3. Aug 4, 2018 at 5:02 PM
    #63
    Slvr14tacoma
    Mid travel
    Ive had this wheel/ tire setup with king 2.5’s set at approximately 2 1/2” for awhile now. Also tc uca’s. Front lift is moderate. I think ive always gotten the truck set to factory specs and didn’t really realize i could give some #’s to better get me where i need to be
  4. Aug 4, 2018 at 8:28 PM
    #64
    splitbolt
    NW Arkansas
    Let's try this a different way...
    What year and model truck do you have?
    Need to know the OEM wheel and tire size.
  5. Aug 4, 2018 at 8:30 PM
    #65
    Slvr14tacoma
    Mid travel
    2014 tacoma. So I believe it would be 7.5x16 oem wheels
  6. Aug 4, 2018 at 8:44 PM
    #66
    Gettin Lost
    Gettin Lost Backwoods Rated
    Florida
    2021 TRDOR
    KDMax tune, eibach stage 2, ceramic tint, DD SS3 PRO fogs. Toyo AT3 285s
    Sorry to jump in the thread like this but can anyone tell me if there is any problems with this alignment? Anything to worry about in the future? Just done a few days ago after lift/ level install.
    No pulling either direction. No rubbing. No vibrations. Ride seems pretty much the same as before the lift and alignment.
    2017 sr5 4x4, came with 245s, I upgraded to 265/75/16, stock UCAs, 3/1 lift/level.
    Thanks so much in advance.
  7. Aug 4, 2018 at 8:46 PM
    #67
    Slvr14tacoma
    Mid travel
    No worries man im not even in the right generation forum
    Gettin Lost[QUOTED] likes this.
  8. Aug 5, 2018 at 2:02 PM
    #68
    splitbolt
    NW Arkansas
    Should be 16x7 ET 30 with a 265 70 16...
    Your new wheels and tire increase positive scrub by 1".
    I'd go:
    +2.5 caster
    +0.25 camber
    +0.05 toe-in
    Leo4x2 and Slvr14tacoma[QUOTED] like this.
  9. Aug 5, 2018 at 2:10 PM
    #69
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Speaking of alignment. How strong are the axles on these trucks. Rear passenger tire drove over a part of a curb turning into a parking lot at 3-5mph. Shook me up a bit.
  10. Aug 5, 2018 at 2:22 PM
    #70
    Slvr14tacoma
    Mid travel
    I stand corrected on the wheel width. Really want to thank you for the taking the time!!
  11. Nov 18, 2018 at 9:21 PM
    #71
    BearOnABicycle
    BearOnABicycle Active Member
    Kevin
    2018 black Tacoma TRD off-road
    Bilstein 5100s front/rear, JBA uca’s, falken wildpeak at3w 285/75/16, 16” trd beadlock style wheels, spidertrax 1.25 wheel spacers.
    Got my alignment done today hoping it would get rid of the rubbing I have on the cab mount. Now it rubs much less but still rubbing nonetheless. My question is..increasing the caster should do the trick right? Or is a cmc definitely necessary?
    Running 5100s all around with ome888 springs and brand new JBA ucas with 285/75/16 falken at3w and trd beadlock style wheels + 1.25 spidertrax.
    Just officially joined Tacoma world but spent many weeks lurking in the forums lol
    Thanks in advance guys!
  12. Dec 1, 2018 at 8:12 PM
    #72
    Otis1382
    Otis1382 Well-Known Member
    warren
    Chelsea Al
    '16 DCOR 4x4 quicksand
    sorry i know this is an old post. i downloaded the manual and searched it. where are the alignment specs?
  13. Dec 1, 2018 at 8:15 PM
    #73
    splitbolt
    NW Arkansas
    Page 8,904.
    JJ Diablo and Otis1382[QUOTED] like this.
  14. Dec 1, 2018 at 8:19 PM
    #74
    Otis1382
    warren
    Chelsea Al
    thanks. i've searched several ways but couldnt find it. i have a lifetime alignment with a shop here in bham and i'm not happy with it. started searching here after i sheared a rear center pin. i replaced it but after my last alignment it seems to be a little "loose". i was going to take it somewhere else but needed the numbers.
  15. Jan 17, 2019 at 8:47 PM
    #75
    CaboTom
    CaboTom Well-Known Member
    San Diego
    2019 Cement Tacoma TRD OR
    Hi guys! I’m about do a suspension install on my truck and I’m hoping someone can chime in and help me out with some alignment specs for my post-install setup. Going to be running Dirt King Heim’d UCA’s with King 2.5 ext travel coils (set at 2.5 inches of lift), and Dakar HD springs. Wheels are 16x8 with 3.5” backspacing and -25 offset. Tires are 265/75/16. From what I’ve read it sounds like I want to shoot for around +4 caster, but I’m slightly confused as to what camber/toe I should aim for. I know it should be close to 0, but I think I need to take into account the squat factor? And scrub? (Confused as to exactly what these are and how I need to compensate for them). Thank you in advance for any and all help.
  16. Jan 17, 2019 at 9:29 PM
    #76
    splitbolt
    NW Arkansas
    +4 is too much caster for 265/75/16. Too much will bumpsteer and transmit more road shock, especially with the 2" of added scrub. More caster creates more movement of the camber and toe under dynamic conditions. I run +2.5 on stock rims with 265/75/16. Since you have an additional 2" of positive scrub to overcome, I suggest +2.8.
    Camber should be +0.5; +0.6 driver/+0.4 passenger if you want to compensate for road crown.
    Toe should be +0.05. With the 2" of added scrub, I'd go +0.07
  17. Jan 17, 2019 at 9:37 PM
    #77
    CaboTom
    San Diego
    Thank you very much for the quick and detailed response. I do plan on moving up to a 285/75/16 in the near future. If you don’t mind, what specs would you recommend with that tire?
    Thank you again for the help.
  18. Jan 17, 2019 at 9:46 PM
    #78
    splitbolt
    NW Arkansas
    That will change the additional scrub to about 1-5/8", so...
    +3 caster
    +0.5 camber
    +0.06 toe
  19. Jan 17, 2019 at 10:12 PM
    #79
    CaboTom
    San Diego
    Thank you very much! I’ll report back once I get the alignment to let you know how she feels. I appreciate all the help.
  20. Jan 24, 2019 at 1:12 PM
    #80
    CaboTom
    San Diego
    Soooo... after going back and forth, and doing some research, I decided to go 295/75/16. Tires should be here in a few days. What should I ask the alignment shop to shoot for? Thank you again for all your help.
