Alignment Specs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by akibia, Feb 25, 2018.
  1. Feb 25, 2018 at 3:35 PM
    akibia
    akibia [OP] Member
    Jack
    MA
    2008 4WD Access Cab TRD MT
    ToyTec 3" Kit Total Chaos UCA's
    Just curious if im wrong here or not. So i originally did a 3 inch toytec lift on my truck. (08 Acc Cab V6) Alignment was obviously off because i hadn't done UCA's at the time. Finally got around to doing UCA's and had it re aligned. (Total Chaos UCA's) Asked the shop for 0 degrees camber both sides and 2.4 caster on both side. Guy told me he could not achieve this because he maxed out the camber and caster settings on both sides and this is what i got.
    Left Side
    -0.8 Camber
    1.0 Caster
    Right Side
    1.0 Camber
    2.1 Caster
    Just wanted to get the community opinion on this because i have seen a few guys with the same set up having no problems getting these specs. Thanks for the input
  2. Feb 25, 2018 at 3:38 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    IMO you need to find a new tech. Those numbers are shitty.
    MolonLabeTaco, MarX and REDdawn6 like this.
  3. Feb 25, 2018 at 3:38 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    That will feel twitchy going down the road. I like my caster above 3 but I have spc uca's so that's easy to dial in. that camber is way off
    Myles G and MolonLabeTaco like this.
  4. Feb 25, 2018 at 3:43 PM
    akibia
    akibia [OP] Member
    Jack
    MA
    That's what i figured
    MarX and EatSleepTacos[QUOTED] like this.
  5. Feb 25, 2018 at 3:58 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Try for these.
    4 castor
    0 camber
    0 toe.
    IIRC
    MarX likes this.
  6. Feb 25, 2018 at 4:02 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That’s about right, but really anything over 3° is good for caster.
    MarX likes this.
  7. Feb 25, 2018 at 6:36 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Guy is not using the stack and drag technique.
  8. Feb 26, 2018 at 2:18 AM
    gTACO671
    gTACO671 Member
    Guam
    2007 Silver Regular Cab 4x4
    Fox 2.0 coilovers front , 1 inch rear block, A.T.O. Shackle flip kit, BAMF shock relocators, 12 inch travel Fox 2.0 Armor SOS Offroad Front aluminum bumper Self built custom high clearance rear bumper with hidden receiver hitch.
    Could have worn parts somewhere down the line. Bent lower control arms or even a slightly bent spindle. In my experience doing alignments, I've encountered many trucks that are stock that sometimes use up all the lower control arm adjustments for camber and caster. I'll get one of these kind of conditions once and a blue moon. But when I do It's from bent spindles. Very small differences.
  9. Feb 26, 2018 at 8:43 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yeah.... go to a proper alignment shop that dude dont know what hes doing.
    I personally like steering feel to be lighter, I ran with 3.4ish* of caster for quite some time but was always annoyed at how sensitve the truck was to road crown because of the high caster and how much wheel force it took to overcome the pull due to crown. (truck would track dead straight on a flat road). Also due to the higher caster bumpsteer was more prevalent.
    Dropped down to ~ 1.7* of caster and things are MUCH better for my taste.
    I do all my alignment at home with all of a 23 dollar digital angle finder and every time I have taken the truck to get a free alignment check at big brand, my calculated numbers are all within .1* I have gotten pretty good at doing it so it makes it easy to adjust things, especially with the SPC UCA's
  10. Feb 26, 2018 at 8:57 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    IDK if TC UCA's can do any camber or caster but those #'s suck. If nothing is bent or wore out, there's no reason one side can't match the other, regardless of lift. I did mine myself. These are my numbers, which are good. The before is what I did myself in my garage & the current is what the tech felt would be best, but I have SPC LR UCA's.
  11. Jan 27, 2019 at 6:15 PM
    FishTacoJon
    FishTacoJon Well-Known Member
    Jon
    AZ
    2012 Tacoma TRD Sport DCSB
    Looks good man. ^ I had been looking back at old alignment sheets as I need to get mine redone and it seems like a decent amount of toe in the rear is just a common thing eh?
  12. Oct 28, 2019 at 5:38 PM
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    Made some adjustments to my coil overs and was able to get these numbers. It rides well and it’s straight.
  13. Oct 28, 2019 at 6:05 PM
    KickAss
    KickAss Well-Known Member
    Chuck
    Florida
    2015 Limited 4x4 DCLB
    Big body sittin on chrome
    just did mine after 3" toytec lift,, wildpeaks 265/70 18
    MolonLabeTaco likes this.
