alignment specs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rogerkamp8817, Apr 28, 2010.
  1. Apr 28, 2010 at 11:15 AM
    rogerkamp8817
    rogerkamp8817 [OP] Well-Known Member
    Huntington Beach, CA
    2010 Toyota TRD Off-Road 4x4, AC, Superwhite
    Where can I find the factory alignment specs or does anyone know the factory specs?
    I just had 5100's installed and took the truck in for alignment. Les Schwab took an hr and a half and the print out they gave me still had some values that were in the red. I'm set at the 1.75 (or 1.5, whatever the 3rd highest clip is) and didn't think aligning it would be an issue.
    I'll post a screen shot of the print out when I get home tonight.
  2. Apr 28, 2010 at 11:17 AM
    JasonJump
    JasonJump Well-Known Member
    Yukon Oklahoma
    '05 Tacoma TRD Sport 4X4 D Cab Debadged
    Billy 5100's set at 2.5, iPhone innerface, TRD Sport wheels powdercoated Anthracite grey wrapped in 265/70/17 Duratracs, Custom Sliders
    can we do alignments on our Tacos?? Like at home.... sorry if that is a stupid question ;)
  3. Apr 28, 2010 at 12:01 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    castor - 2.4
    camber - 0
    toe - 0
    is what everyone around here shoots for in the ton of threads i found while searching (hint, hint!!). w/ 1.75, you should be able to get everything into OEM spec range, although it will be different than above.
  4. Apr 28, 2010 at 1:26 PM
    JasonJump
    Yukon Oklahoma
    Soooo we can do it ourself???
  5. Apr 28, 2010 at 1:34 PM
    rogerkamp8817
    probably not. its more expensive buying the right tools and even then you won't be as accurate as the professionals with lasers and such.
  6. Apr 28, 2010 at 8:07 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    if your even asking this question...no.
    i have a buddy at work that added and extra overdrive gear to his special edition camero and wrote his own fuel maps for the car that always does his own alignments w/ perfect tire wear, but i wouldnt trust the average joe to do it w/o lazers!!
