alignment tech/ help thread
Discussion in 'Suspension' started by livel0veryde, Feb 1, 2012.
  1. Feb 1, 2012 at 11:24 AM
    livel0veryde
    livel0veryde [OP] Well-Known Member
    josh
    missouri
    Tacoma based buggy
    i'm starting this thread so we can have a place to ask questions about alignment related issues, so we dont have to keep posting up new threds every time theres a question.
  2. Feb 1, 2012 at 11:27 AM
    livel0veryde
    josh
    missouri
    Tacoma based buggy
    ill start.
    i went and got an alignment a day or so ago and this is where every things at right now, they told me i need some kind of kit to correct the camber,anyone know what they were talking about?
  3. Feb 1, 2012 at 11:36 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Is your truck lifted? The caster on your driver side is way off. I would imagine the truck pulls to the left quite a bit.
  4. Feb 1, 2012 at 11:47 AM
    livel0veryde
    josh
    missouri
    Tacoma based buggy
    5100s and 882s. it pulls to the left not to bad tho, mostly it just bothers me knowing that somthings off. would a set of uniball ucas fix this.
  5. Feb 1, 2012 at 12:02 PM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
  6. Feb 1, 2012 at 12:28 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Are you 5100s at the stock setting? Yes, a set of UCAs would help. They have more Caster designed into them.
  7. Feb 1, 2012 at 2:49 PM
    livel0veryde
    josh
    missouri
    Tacoma based buggy
    yup, set at zero.
  8. Feb 1, 2012 at 2:53 PM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    Your Camber is not as bad as your Caster.
    If they can get your right to 2.0, they should be able to get closer with your left.
  9. Feb 1, 2012 at 3:04 PM
    livel0veryde
    josh
    missouri
    Tacoma based buggy
    ha ya just realized i messed up in my original question where i said camber i was meaning to say caster.
    thats what i was wondering about.
  10. Feb 1, 2012 at 4:54 PM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Here is my last one for my 4runner. I'm lifted 2.5" in the front on stock UCA's. Might have to invest in some aftermarket UCA's if they can't get my caster down anymore. I've been back 4 times now and every time it pulls to the left. I'm getting annoyed and last time they left the steering wheel crooked. If they can't get it right this time I'm giving up on the place. It sucks because I have a 1 year warranty and went to that place due to the warranty and recommendations from my coworker.
  11. Feb 1, 2012 at 5:32 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Your Caster needs to come way up!
  12. Feb 1, 2012 at 5:58 PM
    SCRunner12
    Robert
    Santa Cruz, CA
    Yeah I know. I'm going to check my other sheets, but the guy didn't even touch the caster that last time. I'm going tomorrow so I'm going to specifically ask them about the caster and possibly give them a write up a member did about aligning a lifted 3rd gen.
  13. Feb 1, 2012 at 6:35 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Caster is ideal around 2.5 with everything else closest to 0. UCA will get you there with little effort but 2 is prob doable with stock??
  14. Feb 1, 2012 at 6:40 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    what should camber be on a 99 with ebaich coils with 5100s at 0?
  15. Feb 1, 2012 at 6:56 PM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    still close to zero
    With my '04 4Runner, with 3" lift. I was able to get to +2.4 caster, both sides, with stock UCAs.
  16. Feb 1, 2012 at 8:50 PM
    livel0veryde
    josh
    missouri
    Tacoma based buggy
    so what do you guys think my plan of action should be? im thinking go to another shop,get an alinement check and see what they have to say about it.
  17. Feb 2, 2012 at 5:14 AM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    I'd either take it back to the first shop if they can do it without cost or go somewhere else.
    But first, with 5100a and 882 at zero, how much lift does that equal?
    I'd go back in with the numbers you want. Typically with a 2 3/4"-3" lift aim for:
    Camber: 0 degrees
    Caster: +2.4 (or more) degrees for 3" lift. A little less is okay for less than 3"
    Toe: 0 to +.04 degrees
    This is how I did it last time. I asked for them to work with me to hit those numbers, I said I wasn't in a hurry, If it took them a little while longer it was okay, those numbers were very important to how the truck was set up, and I thanked them for willing to work with me.
    I think if you go in with the numbers you are shooting for and are pleasant, most folks are more apt to work with you.
    Also ask before hand if they provide before and after readings on a printout. I thought this was standard, but I went to one shop that didn't do printouts and was disappointed, I ended up eating that cost and got it aligned somewhere else.
  18. Feb 2, 2012 at 10:29 AM
    livel0veryde
    josh
    missouri
    Tacoma based buggy
    thanks for the help charles
  19. Feb 3, 2012 at 7:40 AM
    JC47
    JC47 Well-Known Member
    British Columbia
    08 TRD Sport DCLB 4X4
    OME 885, 5100's, 1.5 AAL, DC2's, 265/75/16 Duratracs. Leer Cap, Debadged.
    I just got an alignment on my 2008 with a 2.5" lift, and the caster is showing around 1.1 for both sides (stock UCA's). I realize this is a bit low, but the truck drives nice and straight, no wandering or anything and the rest of the numbers look okay I think (toe is .1, camber .3) Are there any other issues that a low caster number could cause?
  20. Feb 3, 2012 at 8:00 AM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Perhaps a twichiness in steering when hitting a bump
