alignment tech/ help thread
Discussion in 'Suspension' started by livel0veryde, Feb 1, 2012.
  1. Mar 24, 2012 at 12:17 PM
    MountainMan777
    MountainMan777 Well-Known Member
    CA
    07 TRD Offroad Prerunner
    just installed some Fox coilovers and Total Chaos UCAs on my 07 tacoma lifted it about 2.5 inches untill i can get an AAL, and took it to big brand tires to get it aligned. The manager called me out and told me they couldnt align it because the Lower Control arm mounts were bent or something like that and so they couldnt align it anymore and the front passengerside tie rod was bad, But i dont understand how they cant align it when before i installed the front lift it drove perfectly and the lower control arm mounts were exactly the same as they are now? Iv heard of people having the same problem and it might be the Lower control arm bushings wore out and caused the lower control arm to move laterally but i dont know what it is im taking it to a body shop next week to have em look at it anybody know what i could do or try my truck is so bad right now my front passenger side tire squeals when i turn . I am desperate for help! the tire shop gave me a print out of my camber, caster, and toe heres the specs:
    Left side: camber -0.1.....caster 3.3.....toe -2.44
    Right side: camber 0.6......caster 6.1.........toe -1.50
  2. Mar 24, 2012 at 2:44 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    he probably ment that the tabs on the side of the bolt to the UCA's are bent flat which if they are, u wont be able to adjust the bolts. the 2nd gen has very weak tabs and a few people have to had them replaced and total chaos makes a better tab to replace them with
  3. Mar 24, 2012 at 7:26 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    i just had my truck aligned yesterday, specs are:
    left side right side
    camber 0.6 camber 0.9
    caster ? caster ?
    toe .02 toe .02
    I have fox COs set at 3" and camburg ucas, truck drives very straight but the wheels have very noticable positive camber!! It was like this before i went in and i said something to them about the camber. When they were done he said they fixed everything, i asked about the camber and he said there was no way to adjust the camber on my truck! WTF!!! so i just left! How can i adjust the camber myself?
  4. Mar 25, 2012 at 7:15 AM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    i was told this same thing. i wouldnt touch it without a machine. but the big bolt that goes through the lca is what adjusts it. and you are supposed to have some pos camber supposedly. need to go to a rreal alignment shop is what i have learned
  5. Mar 25, 2012 at 7:20 AM
    sir1123
    Charleston
    it supposed to have a little pos or neg camber. i dont know which one.
  6. Mar 25, 2012 at 9:29 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    yeah thats bullshit! Dude told me that camber wasnt adjustable and i didnt even feel like arguing cause if he said that then obviously they dont know how to align it! I guess ill just go to an alignment shop instead of a tire shop. I dont know why u would want pos camber though, especially on the street! If anything it just looks like shit
  7. Mar 25, 2012 at 4:43 PM
    MountainMan777
    CA
    after installing after market coilovers and UCAs on my truck i took it in to get aligned and the tire shop said they couldnt alighn it because of some bs reason that i know isnt the case. I took a look under it and noticed the alignment brackets that hold the lower control arm straight were both bent on the front passenger side so the alignment washer doesnt have that edge to keep it in place due to one side being bent. Does anybody have any advice on what i can do to fix this or where i can take it or if this is even the problem at all?
  8. Mar 25, 2012 at 8:33 PM
    sir1123
    Charleston
    ha i posted this same thing almost word for word. haha dumbasses ya just go to a shop that specializes alignment.
  9. Apr 7, 2012 at 2:46 PM
    livel0veryde
    livel0veryde [OP] Well-Known Member
    josh
    missouri
    Tacoma based buggy
    maybe some of these or make something like it. http://www.polyperformance.com/shop...ower-Control-Arm-Cam-Tab-Gussets-p-24951.html
  10. May 4, 2012 at 9:36 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    aight so i took my truck to an actual alignment shop today and they told me that they had started on the left side, everything adjusted fine but they could only adjust the camber to +.03 before the tab maxed and then the right side would only adjust to +.08 before being maxed out. He said he wasnt sure why this was, maybe an a arm is tweaked some or maybe because of my tires.
    what do yall think? I dont have a diff drop on my truck, yall think that might be it!? He told me if i did anything that i think would help within 60 days they would re-adjust everything for free
  11. May 4, 2012 at 10:55 AM
    livel0veryde
    josh
    missouri
    Tacoma based buggy
    a diff drop will not affect your alignment, it will just lower your cv angle.
  12. May 4, 2012 at 3:58 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Im just tryin to think of anything. Has anyone ever had this problem
  13. May 4, 2012 at 4:06 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    :spy:
    With full LT and my alignment is still in spec
  14. May 4, 2012 at 10:22 PM
    Bee22971
    Bee22971 Well-Known Member
    Garth
    Sacramento
    2011 DC TRD
    King 2.5 C/O, DSM UCAs, all pro leafs, and AllPro Sliders
  15. May 6, 2012 at 1:46 PM
    #35
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    So no one can give me a suggestion on a solution? I have my coilovers set on 3”, would lowering them help??
  16. May 6, 2012 at 7:44 PM
    #36
    livel0veryde
    josh
    missouri
    Tacoma based buggy
    this is on my to do list.
  17. May 14, 2012 at 3:18 PM
    #37
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Do you have stock or aftermarket UCA's? If you have stock UCA's, lowering the coils will help, if you have aftermarket UCA's like Light Racing, they have a camber adjustment on them.
  18. May 14, 2012 at 4:16 PM
    #38
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    i have camburg 1" ucas! I thought about lowering the coils a little bit to see if that helped, u think it still would? They are set on 3"s so pretty they are pretty high
  19. May 14, 2012 at 4:19 PM
    #39
    livel0veryde
    josh
    missouri
    Tacoma based buggy
    ya im pretty sure that will solve your problem.
  20. May 14, 2012 at 4:21 PM
    #40
    Cr250jumper
    The moon
    50 shades of tan©
    I just added a lot more tubing to strengthen that whole area too :D
