alignment tech/ help thread
Discussion in 'Suspension' started by livel0veryde, Feb 1, 2012.
  1. May 18, 2012 at 10:00 AM
    #81
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    if i lifted my coils higher would i gain more camber??
  2. May 18, 2012 at 11:07 AM
    #82
    nvtaco
    nvtaco Well-Known Member
    Vancouver, BC
    07 Double Cap TRD Sport
    Vent visors, backup lights, the loadhandler!
    I have Pirellis Scorpion AT tires. 265/65/17, I think they are the stock size. They didnt follow the ruts before. So do you guys think bumping up the caster a little higher on ea. side. and leaving the camber where it is would be the way to get rid of the squirrly feeling?
  3. May 19, 2012 at 10:33 AM
    #83
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DCSB SR5 V6 AT TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Yes. Increasing the caster should do it. DevL gave you the correct numbers. Try to get the cambers down too.
  4. May 19, 2012 at 12:26 PM
    #84
    nvtaco
    Vancouver, BC
    Thanks guys I will go in today and post my results after the fix.
  5. May 20, 2012 at 4:42 PM
    #85
    anthony250f
    Anthony
    San Diego, CA
    anything look bent?
    driver
    pasenger ( bad side)
  6. May 20, 2012 at 5:12 PM
    #86
    livel0veryde
    livel0veryde [OP] Well-Known Member
    josh
    missouri
    Tacoma based buggy
    not really going to be able to tell from those pics.but you can usually pick up a used LCA and UCA for pretty cheap might just try replacing that or maybe just take it to a frame shop... idk
  7. May 21, 2012 at 12:48 AM
    #87
    DevL
    DevL Well-Known Member
    More lift = more camber.
  8. May 21, 2012 at 12:54 AM
    #88
    DevL
    Yes and yes.
    I know old Camburg uca did not add caster. I have heard recent ones add caster. If you dont have the uca that adds caster that is certainly your issue... too much lift, not enough caster adjustment before you lose the ability to turn camber down. Less lift or adding caster at uca are the solutions.
  9. May 21, 2012 at 8:53 AM
    #89
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Just FYI I sold my stock arms for $50 when I got LT. If you look around you should be able to pick up a used set cheap
  10. May 21, 2012 at 9:55 AM
    #90
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Aight cool! Looks like for now ill be turning my co's down a little bit! Thank u very much sir!;)
  11. May 21, 2012 at 10:26 AM
    #91
    BTO
    California
    Just to reiterate, first thing you should do is verify you do have a problem. Who knows? Maybe the alignment shop screwed up the numbers? I would start by putting a level against the right wheel and see how it compares with the left.
  12. May 23, 2012 at 10:41 PM
    #92
    DevL
    That is fine... but only if tow is .06 and .08 not .6 and .8
  13. May 23, 2012 at 10:44 PM
    #93
    anthony250f
    Anthony
    San Diego, CA
    that was my alignment before i knocked it out... now its
    left
    camber -0.7
    caster 2.8
    toe 0.05
    right
    camber -1.7
    caster 2.6
    toe 0.05
  14. May 24, 2012 at 11:33 AM
    #94
    Cr250jumper
    The moon
    50 shades of tan©
    Do you jump your truck?
  15. May 24, 2012 at 3:17 PM
    #95
    nvtaco
    Vancouver, BC
    Had truck to alingment shop. Feels better now, less squirrelly on the road, tracks straight enough to hold steering wheel with one hand. Previously I could not do that, always correcting.
    Weird thing though, after my Billie 5100 install on the fronts (orig coils .85 setting), the drivers side is now 1" lower than my passenger side measured from centre hub to bottom of fender.....Could that have something to do with why my left and right #'s are so different?
    After alingment #s
    Left front
    Camber -.4
    caster 1.7
    Toe 0.03
    Right front
    Camber -.2
    caster 2.1
    Toe 0.05
    Middle measurements, Front
    Total toe 0.08
    Steer ahead -.03
  16. May 24, 2012 at 3:23 PM
    #96
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    so all my cams are tacked and the tie-rods are marked with a sharpie.
    I hit a gnarly ditch this weekend which knocked my toe out of alignment (steering wheel crooked).
    I get out and inspect; cams all look good, welds have held, and the sharpies marks on the tie rod are all in line.
    What could have happened? bent tie rod? something inside the rack?
    Truck tracks perfectly straight like before, it's just the steering wheel is crooked.
  17. May 24, 2012 at 3:32 PM
    #97
    Cr250jumper
    The moon
    50 shades of tan©
    Mine did the same thing, my steering wheel was dead center and now it is just barely turned, still tracks straight and alignment cams havent moved. Maybe possible to tweak the rack in its mounts? Or tweak the mounts themselves for the rack? Do you still have stock tie rods or heim steering?
    Cp_Yota likes this.
  18. May 24, 2012 at 3:41 PM
    #98
    blackhawke88
    SGV, CA
    07 TRD Offroad
    I have stock rack but HD heim steering from Engage.
    After it happened I did notice toe was a little out (more distance between tires in front than in rear), but only by about 1/8", so i cranked it in til it was negative by about 1/8".
    Everything else is fine.
  19. May 24, 2012 at 3:46 PM
    #99
    BTO
    California
    Yep. I'd take it back. Try to get both casters up closer to 2.8 and about equal. F'n half-ass grease monkeys.
  20. May 24, 2012 at 3:49 PM
    #100
    nvtaco
    Vancouver, BC
    But it does feel ok to drive. Will it (I dont know what, tires or..) wear unevenly?
