Alignment with BFG KO tires
Discussion in 'Wheels & Tires' started by NomolosTRD, Jun 26, 2008.
  1. Jun 26, 2008 at 12:59 PM
    NomolosTRD
    NomolosTRD [OP] Well-Known Member
    I just bought the BFG at Ko tires 265/70/17 load range E and they are great tires. The Place I got them from didn't do alignment, so I took it to the dealer for alignment. They couldn't do It! apparently on these tires there is a rim porotector on the sidewall that makes the bead come past the lip of the rim where the alignment sensor heads mount to. I went to 6 different big name tire and alignment places and no one could do it, and no one has the lug mounted alignment heads. Finally after much searching I found a new lift shop that has some new system that mount to the tires, not the rims so they can do any wheels. I just wanted to let you all know about this problem so you can get it aligned before you get these tires.
  2. Jun 26, 2008 at 4:17 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i had my local dealer install my bfg m/t's and they have the rim protector as well. i only took it to the dealer b/c of the tpms crap. they did it w/ no probs.
