Alignment with bilstein 5100s
Discussion in 'Suspension' started by 98Tacoma, Jan 12, 2011.
  1. Jan 12, 2011 at 5:16 PM
    98Tacoma
    98Tacoma [OP] Well-Known Member
    adam
    V.A.
    1998 V6 xtracab
    k&N intake, 40 flowmaster turndown, westin brushguard,10 inch JL sub, alpine cd player.painted black tool box. bilstein 5100s 3inch Ebiach springs all around and toytec aal. mickey thompson beadlocks. and 33inch goodyear duratracs
    i installed my bilsteins about 2 weeks ago and i took it to school today to align it. im able to get the toe in spec. but i can really get the camber or caster to change any. it seems like the ecentrics dosent seem to push the control arm any. has anyone else had any body had problems alignment with only 2.5 of lift. getting new tires dont want to wear unevenly.
  2. Jan 12, 2011 at 5:40 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You probably need aftermarket UCA's. Most people need them at 3", and it's really hit or miss at 2.5".
  3. Jan 12, 2011 at 7:42 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    i may have to i really hope i dont tho cause i need the tires but if without ucas to correct the camber tires may be a waste of money
  4. Jan 13, 2011 at 6:22 PM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    well, I Have 2.5" lift on my 09 Taco and no need aftermarket UCA . No vibration at all . Tires are wearing out even and truck is running straight .
  5. Jan 13, 2011 at 6:30 PM
    TexasTacoma37
    It's really hit miss at 2.5" some need uca's some don't.
  6. Jan 13, 2011 at 8:45 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    well guys i took it back to school today and got everything straight camber is back at factory spec and toes is also. now i can get the new duratracs
  7. Jan 27, 2011 at 5:45 PM
    TacoBow
    TacoBow Intentionally cosmetically correct.
    Central PA
    2015 Tacoma TRD Sport 4x4 Quad LB
    After visiting the alignment shop, my camber adjustment was on the edge of green (in spec) with just a 2" lift.
    The caster ended up being close, but no cigar. Dialing back in the caster changed my camber settings to outside spec, so I opted for as close to a zero camber setting in exchange for a closer to spec caster setting.
    The toe setting was not an issue, which is a given since it's a tie rod only twist setting.
    My truck drives well with no dive or pull, no road crown issue and no wandering. Having close to a negative caster made the steering a bit lighter than what I'm used to.
    What did you do to gain on your camber / caster settings? I've been told that using a basic ratchet strap to eek out all the slotted mounts will allow before locking down the LCA camber bolts has been done to gain a touch more caster and camber, but I didn't suggest it to the tech since I was already so close to spec.
    I'm interested in what worked for you, seeing that your lift / leveling install is .5 higher than mine. I'd like to get a wee bit more caster without installing aftermarket UCA's...
  8. Jan 28, 2011 at 5:32 AM
    kramer2k
    kramer2k Well-Known Member
    Jacksonville, FL
    08 DC PreRunner TRD OR
    Interesting stuff. ^
    I'm wondering what Toyota will be able to do with mine in the morning. I'm installing the 5100s at 1.75" (with a 1/4" top plate spacer on driver's side) today and getting an alignment done in the morning at the dealership. I'll try to remember to get my before/after numbers for comparison's sake.
    After only switching from stock tires to 265/70/16 size I got a bit of wandering (tracking?) during highway driving. I'm very hopefull I can get within spec with just this slight amount of lift.
  9. Jan 29, 2011 at 11:45 PM
    sanga700
    San Diego, CA
    If your steerling wheel is a bit lighter then u will have wandering when hit 70 or 75 MPH . Tell ur tech to adjust the caster must be 2.0 and up . toe 0.05 . Not sure about camber maybe 1.0 ( I have to look on my aligment paper ) .
    Hope that help.
  10. Jan 30, 2011 at 5:13 AM
    kramer2k
    Jacksonville, FL
    Here are my number from yesterday.
    I installed the 5100s on Friday at 1.75".
    Front Left-------------------------------- Front Right
    Actual___Before -------------------------- Actual___- Before
    0.6° ----- 1.1° ---------Camber------------ 0.4°------- 0.6°
    1.9°------ .03° ----------Caster ------------1.4° -------1.1°
    0.05°---- 0.20°-----------
    Toe-------------- 0.02°------ 0.19°
    11.3°---- 10.7°---------- SAI-------------- 11.2°------ 11.1°
    11.9°---- 11.8°----- Included Angle------ 11.5°------ 11.6°
    -------------------------------Front
    --------------------Actual--------- Before
    Cross Camber-------0.2
    °------------- 0.5°
    Cross Caster-------- 0.5°------------ -0.7°
    Total Toe -----------0.07°------------ 0.38°
  11. Jan 30, 2011 at 6:25 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    caster should around 2.4 & up
    caster 0
    toe 0
