alignment with lift
Discussion in 'Suspension' started by jeremy_283, Dec 29, 2008.
  1. Dec 29, 2008 at 5:02 AM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    is an alignment needed when i lift my front end just 1.75 inches?
  2. Dec 29, 2008 at 5:15 AM
    jeremy_283
    also, is this somthing i can just do on my own? it just looks as if i would be adjusting the camber/caster on my front end
  3. Dec 29, 2008 at 5:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes, you will need an alignment. I wouldnt do it myself without an alignment rack.
  4. Dec 29, 2008 at 6:19 AM
    jeremy_283
    ok, how hard will it be to change my front shocks to bilstein 5100's? if i do that b4 i take it to get my rear TSB then i will have my front end alignment done for free pretty much correct?
  5. Dec 29, 2008 at 6:26 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    True if you do it before free allignmemt but i would drive without one, alot of people have done the install of the shocks not to hard if you have the time and the right tools.
  6. Dec 29, 2008 at 6:30 AM
    jeremy_283
    you mean you would or wouldnt?
  7. Dec 29, 2008 at 6:31 AM
    jeremy_283
    and i would switch them like the day before its scheduled
  8. Dec 29, 2008 at 6:52 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    I think what he is trying to say, if you know how to install the shocks do so before you go to get the other stuff done. This way to take care of everything, and don't have to make seperate trips.
    And YES I would agree you need it alignment.
  9. Dec 29, 2008 at 6:54 AM
    jeremy_283
    how hard will it be to put the coils on the 5100's at the 1.75 setting??? sorry i know i ask alotta ???'s
  10. Dec 29, 2008 at 7:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not too hard. The hardest part is haveing the springs compressed.
  11. Dec 29, 2008 at 7:01 AM
    longbow
    Bill
    Indiana
    Can't help you on the coils, I know you need special tools (I do believe) for that. Some here have done it, and they will most likely shout out.
    I let a shop take care of my needs, but then it is nice to have friends.
