alignment woes
Discussion in 'Suspension' started by straycat241, Apr 1, 2010.
  1. Apr 1, 2010 at 10:29 AM
    straycat241
    straycat241 [OP] maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    so i put on my total chaos lca's and tried to get my alignment as close as possible to the old one and i guess i stripped out a cam bolt because the place i took it too was complaining and said they had a hard time they bent my cam tab and they charged me $48 for doing it :( here is pic so now i have a apt. with dmz monday to fix what that that shop did + i got a new cam bolt assembly coming from the dealer today
  2. Apr 9, 2010 at 12:32 PM
    straycat241
    paul
    so this past monday i went down to the dmz shop and they set me straight they fixed my bent cam tab that this "alignment shop" messed up all i can say is the dmz service is top notch here is a pic of it after, now all i need is a good ole alignment
    all 8 outer tabs have been reinforced by placing a weld bead next to it
  3. Apr 9, 2010 at 12:37 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    The cams on these truck freeze in the LCA because they're not lubricated from the factory. Mine flattened themselves without ever going to an alignment shop.
    Don't blame the alignment shop. Blame Toyota.
  4. Apr 9, 2010 at 12:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  5. Apr 9, 2010 at 12:41 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    i say blame cmack
  6. Apr 9, 2010 at 12:42 PM
    straycat241
    paul
    yah when i was replacing my lca's the bolt it self was a bit of trouble getting out im glad the tc lower have zerks on them at least
  7. Apr 9, 2010 at 12:46 PM
    mjp2
    NJ
    At least they apologized for Brian Adams. :D
    x2. F that guy! :p
  8. Apr 9, 2010 at 1:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes...But the damage has been done :(
    *Cuts like a knife is going thru my head now*
  9. Apr 9, 2010 at 1:42 PM
    mjp2
    NJ
    Damnit Chris get out of my head!!!!!
    *runs away screaming*
