alignment won't stay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by alexrosado, Jan 22, 2013.
  1. Jan 22, 2013 at 6:33 PM
    alexrosado
    alexrosado [OP] Well-Known Member
    Alex
    Fort Hood, Texas
    TRD Sport
    6'' suspension lift, 3'' body lift, NFAB nerf bars, flow master exhaust with 3'' pipe, TRD cold air intake, grill guard with hella lights. LED Halo Projector Headlights, redlinetuning hood lift assists.
    about two months ago I got my tires aligned, few weeks later I had some wobble in my steering wheel again so I went to a different place, got it aligned again and once again a few weeks later, wobble in my steering wheel. so I took it a few days ago to get aligned at the same place and again I got the wobble. So I guess my question is, is there a reason I cant really get my truck to stay aligned? and if so, can it be fixed?
  2. Jan 22, 2013 at 6:34 PM
    seric007
    seric007 Well-Known Member
    post up some pics. how are the control arms, upper and lower. how about the eccentrics. spindle? bearings?
    what did the alignment shops say when you asked them.
    lift? rims? details! details!
  3. Jan 22, 2013 at 6:37 PM
    alexrosado
    Alex
    Fort Hood, Texas
    TRD Sport
    I have 6'' suspension, 3'' body. rims are 17'' pro comps, 35'' pro comp tires, 1 1/2 spacers, I'll take some pictures of her underparts tomorrow lol...
  4. Jan 22, 2013 at 6:40 PM
    seric007
    oh boy, I'm no drop-bracket expert but something must be loose. yeah i know, i couldnt be more vague right? :D i'd say pics and go from there
  5. Jan 22, 2013 at 6:40 PM
    Super Black Taco
    Super Black Taco Well-Known Member
    Grayson
    Redwood valley, CA
    09 TRD SPORT 4x4
    OME 885 1/4 spacers,Dakars, 3* shims,Light Racing UCA BHLM,Wicked Flow Muffler, JL sub, Alpine amp, URD Short Throw Kit, U-Bolt Flip kit, 285/70/17 hankook mt
    Sounds more like your tires are not balanced very well.
  6. Jan 22, 2013 at 6:46 PM
    alexrosado
    Alex
    Fort Hood, Texas
    TRD Sport
    I had like 3 different places balance em, supposedly they're fine...
  7. Jan 22, 2013 at 6:51 PM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    :cool:
    Or maybe they're balanced fine initially, but then the wheel weights come off shortly thereafter making things out of balance?
  8. Jan 22, 2013 at 6:53 PM
    alexrosado
    Alex
    Fort Hood, Texas
    TRD Sport
    hmmm...
  9. Jan 22, 2013 at 6:53 PM
    seric007
    alignment can cause a wobble if off enough... lets say an eccentric keeps loosing up, for example. dosent make sense and the alignment shop should be giving you some sort of feedback when they are doing the alignments. that is unless you stomp over curbs at 45 or something every morning.
  10. Jan 22, 2013 at 6:55 PM
    alexrosado
    Alex
    Fort Hood, Texas
    TRD Sport
    hahahaha I try not to, nah unless I'm mudding I drive slow, and I drive carefully lol.
  11. Jan 22, 2013 at 7:01 PM
    seric007
    :laughing:
  12. Jan 22, 2013 at 7:06 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Maybe has to do with your stacked lift :facepalm: :cookiemonster:
  13. Jan 22, 2013 at 7:38 PM
    alexrosado
    Alex
    Fort Hood, Texas
    TRD Sport
    lol that was a long time ago....Haven't driven like that since then haha. and could it just end up being "hey you have too much lift, you're shits always gonna wobble"?
  14. Jan 23, 2013 at 4:11 AM
    Hubs
    Hubs Well-Known Member
    Got mud stuck on the inside of your wheels??? Check that....
  15. Jan 23, 2013 at 4:29 AM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    I would start here too!
    Also, this isnt always a bullet proof test by all means, but it has worked for me in different vehicles….
    -if its just wabble its most likely balance
    -if its alignment, the car should jerk or pull to either side while coasting on a flat surface and it tends to get more aggresive when you step on the break lightly….
    good luck!!!
  16. Jan 24, 2013 at 6:39 AM
    alexrosado
    Alex
    Fort Hood, Texas
    TRD Sport
    Hmmm in that case it's probably just the balanced that wasn't done properly, it wobbles but doesn't drift to one side or the other
  17. Jan 24, 2013 at 9:27 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    defective tire maybe
  18. Jan 24, 2013 at 9:31 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Worn suspension components? Check the tie rod ends, steering knuckle/pitman arm, ball joints, wheel bearings, etc.
  19. Jan 24, 2013 at 9:40 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Which Pro Comp wheel model do you have? Some Pro Comp wheels are not hubcentric, so they can wobble if not centered correctly. Do you have a plastic centering ring for each wheel?
  20. Jan 24, 2013 at 9:46 AM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    I'm saying the wheels to, does the alignment place give you numbers of what they were to what they put?
