Alignment write up?
Discussion in 'Street Trucks' started by pinktaco808, Jul 28, 2010.
  1. Jul 28, 2010 at 11:39 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    can we have a DIY writeup on this thanks
  2. Jul 28, 2010 at 11:49 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Take it to a shop. You need an alignment machine to do it right and most people don't have one of those.
  3. Jul 29, 2010 at 4:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    On IFS vehicles...you can't really do a 'home' allignment. Special equipment is needed to check the overall position of the wheels for every possible adjustment they can make (toe, camber, caster).
    On solid front axle vehicles...you can adjust the toe adjustment and that's about it.
  4. Jul 29, 2010 at 4:13 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    My mechanic told me a good machine costs $40,000
  5. Jul 29, 2010 at 4:50 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Where do I order?
  6. Jul 29, 2010 at 8:58 PM
    pinktaco808
    so why do people say that they do it them selves???
  7. Jul 29, 2010 at 9:01 PM
    davidsdad
    davidsdad Well-Known Member
    Dave
    Grove City, Ohio
    Reg. Cab 4X4
    "Under Cover" Bed cover, 3" Suspension Lift, Sony stereo, 600w amp, Rockford Fosgate 12" sub, wheels, tires, (window tint coming soon).
    Harbor Freight, LOL!
  8. Jul 29, 2010 at 9:59 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    because they have a solid front axle vehicle. If they said they do it themselves on an IFS, they only made the alignment worse.
  9. Jul 29, 2010 at 10:01 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Like whom? :eek:
  10. Jul 29, 2010 at 10:23 PM
    pinktaco808
    i was reading in CT people that are slammed like the white 2nd gen with the cover
  11. Jul 29, 2010 at 10:24 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    They must work at a shop with access to a machine.
  12. Jul 29, 2010 at 10:44 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    You can adjust the alignment with a tape measure. Alignments have been done manually long before the machines came out. It's like saying you can't do math without a calculator (sadly, this is actually true for most people.)
  13. Jul 29, 2010 at 11:31 PM
    pinktaco808
    so where the write up and how too
  14. Jul 29, 2010 at 11:36 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    x2, I gotta see this:confused:
  15. Jul 30, 2010 at 12:02 AM
    all.on.black
    Auburn, WA
    If you're asking this question then you have no business doing an alignment. Nor am I doing a write up. I'm merely stating that it can be and has been done without a machine for a long time.
    Toe you can adjust with a tape measure. Set your steering wheel straight and measure the toe. You'll either have toe in (the distance between the front of the wheels is less than the back of the wheels) or toe out (opposite of toe in). Adjust to the proper specs (look them up)
    Caster is the angle which the steering pivot axis is tilted rearward or forward. If the top pivot is positioned further rearward than the bottom pivot then you have positive caster and vice versa. Once again can be measured and adjusted to the correct specs.
    Camber you can also adjust with a tape measure or string. Have the vehicle on level ground and check if the camber is in or out. Measure from the bottom of one rim to the bottom of the other. Adjust the camber to specs (look them up).
    Machines only make it easy for someone to look at a screen and have it tell them if it's right or wrong.
  16. Jul 30, 2010 at 12:11 AM
    Janster
    Jandy
    Lancaster, PA
    Have you even tried searching www.google.com???????
    If nobody has posted a writeup here....then obviously, you're not gonna get one.
    Good Luck doing the allignment yourself.
  17. Jul 30, 2010 at 6:43 AM
    pinktaco808
    just was saying
  18. Jul 30, 2010 at 6:54 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Very true! I would imagine the only alignment you would want to attempt manually would be on a dedicated trail machine that won't see high speed travel.
  19. Aug 6, 2010 at 11:44 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Spend the $50-$70 and get it done right. Not with string or tape measure...
  20. Aug 6, 2010 at 8:25 PM
    pinktaco808
    ok thanks man they charge like 80 down here
