Alignment
Discussion in '1st Gen. Tacomas (1995-2004)' started by rrosebr, Sep 2, 2010.
  1. Sep 2, 2010 at 7:11 PM
    rrosebr
    rrosebr [OP] Active Member
    Drew
    Blacksburg, VA
    04 4x4 Dbl Cab V6 TRD
    K&N Air Filter, K&N Oil Filter, Security System MOD, Line-X Bedliner, Fog Light MOD
    How often do you do an alignment?
    Stock size tires and suspension (TRD).
    Thanks in advance,
    Drew
  2. Sep 2, 2010 at 8:19 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    at least every time you replace the tires.
  3. Sep 2, 2010 at 10:16 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    When you feel your truck pulling to either side when you drive.
  4. Sep 2, 2010 at 10:27 PM
    kyle39
    kyle39 Reppin' BC
    Kyle
    Vancouver BC
    04 Tacoma Trd
    Deck plate mod, rhino lined, A.r.e. flush glass shell, 265/75/16 Duratrac's, MB72 rims, Full OME lift, Dakars in the rear, Tint allround
  5. Sep 3, 2010 at 11:20 AM
    01taquito
    01taquito "thats what she said"
    joe
    san antonio
    01 pre-runner sr5 quad-cab
    Bilsteins 5100's front and back. Wheelers add a leaf
    getting mine done today for the first time since i've owned it....
  6. Sep 3, 2010 at 11:27 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I take my cars in for alignments when they need them. I don't take them in on a routine basis. It's not preventative maintenance.
  7. Sep 6, 2010 at 11:07 PM
    rrosebr
    Drew
    Blacksburg, VA
    Do you not consider it preventative maintenance to increase the life of your tires?
  8. Sep 6, 2010 at 11:11 PM
    tacoma92
    tacoma92 Black Hole Sun
    Forrest
    Gulf Shores, Alabama
    09 SR5 Toyota Tacoma
    When i got my tires they told me every 5000 miles. That reminds me im a little overdue by a few thousand miles:D
  9. Sep 6, 2010 at 11:12 PM
    tacoma92
    Forrest
    thats just to make sure they are still aligned though
  10. Sep 6, 2010 at 11:22 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I could see (and recommend) rotating every 5000 miles - every oil change, but not an alignment. I couldn't imagine popping down another $50+ every time you changed your oil...
  11. Sep 6, 2010 at 11:33 PM
    tacoma92
    Forrest
    yea thts kinda why i havent done it in a while
  12. Sep 6, 2010 at 11:43 PM
    Jerry299
    Jerry299 Well-Known Member
    Jerry
    Santa Barbara
    4X4 2nd Gen
    LOOK at your tires. Uneven tread wear, get your alignment checked out. If everything looks fine you're more than likely ok
  13. Sep 7, 2010 at 12:12 AM
    rrosebr
    Drew
    Blacksburg, VA
    I didn't, in any way, hint at an alignment every oil change. I did however, read an article that recommended one every year. I guess I am only curious because I've had a car with a bad alignment record before. When I did finally have it aligned i was stuck with tires that had a "whomp, whomp, whomp" tone (related to wear I couldn't SEE).
  14. Sep 7, 2010 at 12:16 AM
    Jerry299
    Jerry
    Santa Barbara
    4X4 2nd Gen
    no feathering either??
    dont mean to set it in stone as far as pass fail with a visual inspection..just a good start i think
  15. Sep 7, 2010 at 6:24 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I wouldn't go as long as "Every tire change" or those tires changes will be closer together than needed.
    I also would recommend the "life time alignment" from a place like Firestone...I got mine aligned 3 times in a week as I adjusted my lift and had it settle. Then I go if I can feel an issue or once a year...which ever comes first.
