Alignment!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by luis2005, Nov 28, 2008.
  1. Nov 28, 2008 at 8:02 PM
    luis2005
    luis2005 [OP] New Member
    Texas
    GOLDIE
    Brush Gaurd/Running Boards/Bed Cover/Leather
    I cannot get my truck aligned properly. Ive gotten new tires still drifts right. I had it done at an independent shop once and once at the dealer. It drives me crazy.
  2. Nov 28, 2008 at 8:10 PM
    rick
    rick `
    1st post????? what size wheels did you get. could be you need new uca's and welcome to TW
  3. Nov 28, 2008 at 8:13 PM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Welcome to TW. Sorry to hear about your alignment. What has the dealer said about it?
  4. Nov 28, 2008 at 8:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to Tacoma World. Could you post the alignment numbers from your last alignment?
  5. Nov 29, 2008 at 5:24 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Have you checked your tire pressure lately? Is it the same side to side?
    Have you looked at your brakes lately?
  6. Nov 29, 2008 at 5:33 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    You mentioned new tires, have you gotten them checked? Balanced and road force tested?
  7. Feb 11, 2009 at 4:46 AM
    ballon78
    ballon78 Well-Known Member
    Amesbury, MA
    06 CC SR5 TRD
    Mine does the same thing, pulls right after i had bf goodrich mud -terrains put on. Two alignments and still the same from two different shops. I started a thread asking about it too and it seems that everyone says UCA's will fix the problem, now just need to pick up a set, just sucks that they are $500-$700. I wouldnt worry about it for now, mine also wanders bad..
  8. Feb 11, 2009 at 5:35 AM
    freesample
    freesample Well-Known Member
    Newfoundland, Canada
    09 Tacoma Double Cab TRD Sport LB
    Visors, Deflector, Husky Liners, too expsensive for good ones :(
    mine is an 09 and it wanders to the right since ive had it.. thought it was normal cause of road crown
  9. Feb 11, 2009 at 5:38 AM
    ballon78
    Amesbury, MA
    06 CC SR5 TRD
    go on highway and when your in the right lane let go of wheel and it pulls/wanders to right, now go to left lane and let go and it stays straigt and starts to pull left a tinny bit....but ya mine pulls right much more, hardly at all to the left.
  10. Feb 11, 2009 at 5:49 AM
    freesample
    ok but if something hits me while im in the left lane im blaming you lol
  11. Mar 19, 2009 at 1:53 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I have a similar question and thought I could jump into this thread. I had some problems with alignment with the stock Rugged Trails on my 06 Double Cab 4x4. The truck slightly pulled to the right when I let go of the steering wheel. The tires got very worn on the inside edge of the passenger front tire and slightly worn on the inside edge of the driver front. I knew I needed an alignment but I wanted to wait until after I got new tires. I got some new tires installed (Pro Comp M/T 265/75/16) and had the truck aligned. After the alignment the shop (Sears) gave me a print out and showed me that the "Toe" was off for both front tires and they repaired it.
    After driving away I notice that the truck still pulls to the right. Just about the same as before. I took it back to Sears and they put it back on the lift, ran their computer (lasers and mirrors...) gave me another print out showing that everything was in the green. They say there is nothing else they can do. No adjustments needed.
    So, the truck still pulls to the right and I don't want to wear out the new tires. I have checked the pressure and both tires are the same.
    Any ideas? Should I try to adjust the tie rods at home?
  12. Mar 19, 2009 at 3:13 AM
    anestech*
    anestech* Well-Known Member
    Las Vegas, eNVy
    07 4x4 DC LB Indigo
    5100s, 285 Revos, TSB, 1.5" blocks, BHLM, Debadged, Linex'd Stubbs Sliders, Undercover, URD intake, URD MAF cal, Flowmaster DOS kit, relocated trailer light plug, Weathertech, Timbren, relocated rear diff vent, etc
    My shop swears by about 1/2 degree of cross caster to compensate for road crown. Seems to help. Truck drives straight, it just has about .5* positive camber which makes me insane. Need to get UCAs...
  13. Mar 19, 2009 at 4:41 AM
    DDD
    Derek
    Santa Clarita, CA
    So with a stock truck & stock tires I cannot get a good alignment without replacing the stock UCAs with aftermarket UCAs?
  14. Mar 19, 2009 at 4:55 AM
    DDD
    Derek
    Santa Clarita, CA
    Here is the numbers from the latest alignment
  15. Mar 19, 2009 at 5:32 AM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    You are well within specs on the vehicle has anyone swapped your front tires left to right to see if you have a tire pull. If not try switching just the front tires and see if she goes left.
  16. Mar 19, 2009 at 5:43 AM
    DDD
    Derek
    Santa Clarita, CA
    I had the "pulling the right" with my old tires. I just got new tires and I have the same problem... And yes, I have rotated the tires to see if that helps. So, I don't think the tires are the problem.
  17. Mar 19, 2009 at 6:58 AM
    Snyperx
    Snyperx Seniore Marcos
    Mine is pulling right also and this is after I did the UCAs. I installed a pair of the Camburg Ball-Joint based UCAs ($360 shipped). My Caster is 2.1 on both side and my Toes is .04 on both side. Now my Camber is what is screwed up, it is .2 on driver and 1.1 on passenger. The Camber was worse after the alignment. I watched the tech try and get it dialed in for two hours and he could not. He even had one of the cams maxed out. He was even using the Hunter Hawkeye laser rack. I am not happy. I am going to be taking it to a shop that does more exotic alignments. To add I was talking with Neubs on this board and he said it took 8 alignments to get his truck the way he wanted. Here is a pick of my results:
  18. Mar 19, 2009 at 10:14 AM
    anestech*
    Las Vegas, eNVy
    07 4x4 DC LB Indigo
    Sorry, that was a referrence to me needing UCAs with a lift. You should be able to dial it in just fine at stock height. Tire size doesn't matter, it is lift that will push it out of spec.
  19. Mar 19, 2009 at 3:56 PM
    dirthawker1313
    dirthawker1313 Well-Known Member
    just put a little less pressure in your left side tires..:D
  20. Mar 19, 2009 at 8:33 PM
    DDD
    Derek
    Santa Clarita, CA
    Believe it or not, I actually tried that yesterday. I drove with the left front at 30 psi and right front at 38. Still didn't help much.
