Alignment!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by luis2005, Nov 28, 2008.
  1. Mar 19, 2009 at 8:46 PM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    I have a similar issue to yours my toe and caster is dead on but I am back on right side and forward on my left and not by much but more than my factory cams can adjust to. I do not know if your springs have the abilty to be loosened and turned so you can rotate the spring itself. My lift gives me the ability to do this and you should be able to also do this. There was TSB on Camry's and Solaras for a pulling condintion and rotating the spring was part of the TSB. It works like a champ. I will do this to my truck as I get the time and since it is not a tire wear issue I am not overly concerned, but my steering wheel is slightly off and she does drift/pull right.
  2. Mar 19, 2009 at 9:27 PM
    thebigk
    thebigk 6 Double 5 3 2 1
    Ken....
    Odessa, TX
    I had the same problem on my old Dakota.....pulling right.....had it aligned & still didn't fix it.
    It was the balancing on the tires.
  3. Mar 21, 2009 at 11:54 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Well, I was about to start wrenching on my truck. I was going to make small adjustments to my tie rods. Turning the right front tire towards the left a little to stop my truck from pulling to the right. Then I noticed the rear alignment numbers. Is that toe numbers in the rear bad? I think there is no way to adjust the rear toe...
    Its so frustrating having to hold the steering wheel from pulling my truck to the right.
  4. Mar 21, 2009 at 11:57 AM
    DDD
    Derek
    Santa Clarita, CA
    Also, anyone know if a positive number is left or right? If my right front tow is +.o2 is that pointing towards the left or the right.
  5. Mar 21, 2009 at 12:38 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    A good alignment tech should be able to dial out a pull (if it's not in the tires). If all they do is point to the caster/camber/toe within spec, they aren't very skilled. A great tech will test drive and eliminate that before you even ask.
    Good alignment techs are really hard to find. Nobody pays what it is worth. If you do locate one treat him right. I usually drop a modest tip if it's a good job (green printout, wheel straight and no pull).
    My last alignment was at dealer (after TSB). Wheel was off center and it pulled right afterward. I told them to keep it until they got it right. They did, but it took a whole day.
  6. Mar 21, 2009 at 5:43 PM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    i have the same problem after the lift 2.5 toytec coilovers, aal rear, 285-60 18 its pretty annoying ,whats going to help out the situation
  7. Apr 1, 2009 at 12:22 PM
    Snyperx
    Snyperx Seniore Marcos
    Well just got back from the second alignment and WOW what a difference!!! I think I found my alignment shop!!! I will post my new alignment specs once I get it scanned.
  8. Apr 25, 2009 at 11:36 PM
    blackphantom09
    blackphantom09 Newbie
    V.B., VA
    09 Double Cab TRD-Off Road SB
    TRD Exhaust, Black badges, Jason Rage tonneau bed cover, TRD S/C, OEM roof rack, Avid Light Bar
    Just curious, what would cause cross camber to be out of spec but everything else be in spec? I got an alignment done and everything is in spec except for the front cross camber. I plan on taking it back to the dealer to see whats up with it.
  9. Apr 26, 2009 at 7:18 AM
    Tacoma2008
    Tacoma2008 Active Member
    Pikeville, NC
    2008 Tacoma Dble Cab
    Kenwood Sound System, Backup camera, side-steps, LED tail lights.
    Positive front toe means it is pointing in, doesn't matter whether it's on the left or right side.
  10. Apr 26, 2009 at 7:24 AM
    Tacoma2008
    Pikeville, NC
    Cross camber is the difference in camber readings between the left and right sides. Most manufacturer allow a 1/2 degree to a full degree before being out of spec. I think our Taco's like the 1/2 degree more. If it's out of spec, then an adjustment needs to be completed.
    (Camber tends to pull to the side with the most positive degree.)
  11. Apr 26, 2009 at 7:30 AM
    Tacoma2008
    Pikeville, NC
    I would be curious to know how you can change rear individual toe on a solid axle? (See Printout):confused:
    But with camber more positive on the right and more negative on the left, it will most definitely pull.
  12. Apr 27, 2009 at 5:50 PM
    rnnonmt
    rnnonmt Tacohd
    Mesa (the desert) Arizona
    06 AC TRD OFF-RD
    3" toytec springs, AAL's, BFG A/T 285/75-16
    Dear Taco heads,
    I'm new to the forum and have been reading all of the alignment issues after lifts were installed. I appreciate the info but my brain is about fried with the subject. As you can guess I am having alignment problems so I will start from the beginning.
    2006 4x4 off road trd access cab with ToyTec 3" front lift (new springs), 2.5" rear lift AAL's and new BFG 285/75-16's. All else is completely stock.
    I am mechanically inclined and installed the lift myself. Prior to installing the lift I drove 40K miles with the truck stock (had 265/70-16 BFG rugged's). The truck has always steered/handled nicely. Eventually I had front tire wear bad on the inner tread and decided to do the lift and new skins. After installing the goodies the truck actually felt better steering and handling. Being concious of my $900 new tires I took it to toyota for an alignment to get the most life for my tires. This is where the nightmare begins.
    I been back complaining to toyota twice now with two seperate alignment checks with print outs within 4 days off each other. I only put 80 miles on the truck in 4 days and the alignment printouts are considerably different. The truck is drifting/pulling to the right slightly on the highway. I dont notice any drifting pulling on while at slower speeds up to 45-50 mph. If you view the truck from the front end it appears that the front tires are "riding on the outbd edge." The passenger front tire is visually obvious that is leaning outbd at the top of the tire. Can you all help me decipher what I have explained physically with reference to the attached alignment sheets. Sorry guys.... cant figure out how to attach the alignment sheets maybe someone explain that one to me also.
    Sincere appreciation,
    Rnnonmt
  13. Apr 27, 2009 at 5:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You want to have your alignment as follows:
    Camber: 0*
    Toe: 0*
    Caster: 2.3* to 3.1* (BUT, as you are lifted 3" with no mention of aftermarket UCA's, your Caster may be closer to .6*)
    Sounds like the Camber is out of wack. Have them do it again, and tell them to set to the values I listed.
  14. Apr 27, 2009 at 5:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    AND, WElcome to TW! :)
  15. Apr 27, 2009 at 6:37 PM
    #35
    rnnonmt
    rnnonmt Tacohd
    06 AC TRD OFF-RD
    Thanks for the welcom Chris4X4.
    Yes, I have stk UCA's and Yes you are right on with your assumption of degrees of my caster. I would like to post the alignment results so you all can see and help explain to me what is going on. I think I am worse than before I had it aligned Do you know how to upload an attachements so I can post the alignment results?
    Rnnonmt
  16. Apr 27, 2009 at 7:05 PM
    #36
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think you have to go into your gallery or something like that.....CAn you just tyoe the numbers?
    Caster?
    Camber?
    Toe?
    For each side?
  17. Apr 28, 2009 at 7:02 AM
    #37
    rnnonmt
    rnnonmt Tacohd
    06 AC TRD OFF-RD
    Original #"s before alignment
    L camber 1.1 R camber .6 Cross camber .6
    L caster -.3 R caster -.4 Cross caster .1
    L toe -.34 R toe -.19 Cross SAI -.4
    L SAI 11.0 R SAI 11.5 Total toe -.54
    L Inc Ang 12.2 R Inc Ang 12.1
    After 1st alignment
    L camber 1.0 R camber .8 Cross camber .2
    L caster .9 R caster .5 Cross caster .4
    L toe 0 R toe 0 Cross SAI -.2
    L SAI 11.1 R SAI 11.3 Total toe 0
    L Inc Ang 12.1 R Inc Ang 12.1
    After 2nd alignment (drove 80 highway miles since 1st alignment)
    L camber 1.5 R camber .4 Cross camber 1.2
    L caster .8 R caster .7 Cross caster .1
    L toe .01 R toe 0 Cross SAI -.9
    L SAI 10.7 R SAI 11.6 Total toe .01
    L Inc Ang 12.3 R Inc Ang 12.0
    Thanks guys. What do you think is going on? Rookie alignment tech? Didnt tighten nuts and bolts well enough after adjustments? .....
  18. Apr 28, 2009 at 8:41 AM
    #38
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok......Caster looks to be as good as it will get with your lift and stock UCA's
    Toe looks fine
    BUT, the Camber is out of wack.
    Camber needs to be 0* L and R.
    Tell then to re do it. Also, tell them to set as follows
    Camber: 0*
    Toe: 0*
    Caster: .6/7*
    The guy is an idiot, and have them make it right.
  19. Apr 28, 2009 at 5:01 PM
    #39
    rnnonmt
    rnnonmt Tacohd
    06 AC TRD OFF-RD
    Thanks again Chris4X4. I called toyota corporate and told them of my experience with one of the local toyota dealers in the valley and I got a return call from their customer relations mgr today. Finally, someone who wants to help make it right again. I think I figured out how to do the attachments.:)
    Rnnonmt
