Alignment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Guy11, Mar 6, 2012.
  1. Mar 6, 2012 at 8:11 AM
    Taco Guy11
    Taco Guy11 [OP] Well-Known Member
    Joe
    Western Maryland
    2020 Tacoma TRD off-road
    First question is am i gonna be able to drive my truck like 10 minutes from the shop to the tire shop to get the alignment done after a 3" lift or is it going to be unsafe to do so?
    Also i have read alot of different post on here about alignment spec and they all seem different so sorry for the repost but ideally what am i looking for my alignment numbers to be on my 4x4 2011 double cab tacoma?
    Thanks Guys.
  2. Mar 6, 2012 at 8:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You will be fine to drive short distances. For alignment, you want:
    Toe: .05*
    Camber: .4*
    Caster: 2.1* to 3.0*
  3. Mar 6, 2012 at 8:51 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    not to argue, cuz i dont honestly know, but i was told that you wanted toe and camber as close to 0.0 as possible. was that misinformation from the tire guy chris? just wondering if i need to go get my alignment redone.
  4. Mar 6, 2012 at 10:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    With Toe at .05*, thats half of a tenth of a degree. You want it slightly posative, and at the spec I gave. .03 to .08 is fine.
