Alignment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Unchained 5150, Nov 16, 2015.
  1. Nov 16, 2015 at 9:48 AM
    Justinlhc
    Justinlhc Not looking for a relationship
    Agreed.
  2. Nov 16, 2015 at 9:49 AM
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    So back I should go for the 0.0 Camber and 2.0 to 2.2 Caster you think gents?
  3. Nov 16, 2015 at 9:50 AM
    Justinlhc
    That's what I like about my LR UCA. Plenty of room for adjustment.
    YotaDriver631 likes this.
  4. Nov 16, 2015 at 9:50 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    thats what i would do.... if anything 0 camber, you dont want positive camber.
    or sell the camburg arms and get some lightracing ones. 3.4* of caster is SOOO NICE.... and i still have TONS of play in the lower arm and an extra 2* of caster availability in the top.
  5. Nov 16, 2015 at 9:51 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Yea, That's the consensus. So much agreement in this thread. That doesn't happen often lol. I wouldn't be disappointed just yet. My guess is that it will drive great with 2.1ish caster. Mine is only at 1.1 and it's not terrible but just enough to be annoying.
  6. Nov 16, 2015 at 9:51 AM
    Unchained 5150
    Rick
    Auburn Ma
    Okay I will call him back and have him fix it
  7. Nov 16, 2015 at 9:52 AM
    Unchained 5150
    Rick
    Auburn Ma
    Thanks everyone now lets hope he doesn't charge me another 70.00 just to fix it
  8. Nov 16, 2015 at 9:53 AM
    nd4spdbh
    SoCal
    Thats how i found my truck to be at 1.4* of caster... it drove alright but it was annoying.... now that i got my lightracing arms in and a proper alignment.... 3.4* of caster the bitch tracks like a freight train... i didnt know what i was missing.
    I am surprised you are only able to get ~2* out of those camburg arms on a 3in lift.
    rngr[QUOTED] likes this.
  9. Nov 16, 2015 at 9:53 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    I know somebody that will buy them if you go this route:spy:
    nd4spdbh[QUOTED] likes this.
  10. Nov 16, 2015 at 9:54 AM
    Unchained 5150
    Rick
    Auburn Ma
    I let go of mine on the highway for at least 2 minutes and it just stayed straight down the road. This sucks
  11. Nov 16, 2015 at 9:55 AM
    Elevated
    Elevated Well-Known Member
    Sergey
    Tracy, CA
    97 Tacoma Extended Cab. 3.4L
    Original Tacoma: 6" lift, air bags in the rear, 17x9.5 XD Series rims w/ 35" Cooper STT Pro tires. Body Armor rear bumper with swing arm tire mount, TRD Exhaust, URD True Cold Air intake, TRD Front Brakes, RIGID INDUSTRIES grill and LED bar installed in it, LED Rear Lights, TracRack rack system, tool box. Sold the truck. Bought 2016 ram 2500 Laramie diesel. (7/2016) Picked up 97 Tacoma 4x4 Extended Cab 3.4L. Building motor now. (8/2017)
    Agree. Running a hair of positive tow will keep the truck straight while driving. Otherwise you'll be constantly making minor adjustments to steering while driving. I dealt with that for a while myself.
    Second, if you plan on going off road, the alignment tabs will bend and truck won't hold alignment. My truck did only minor offroad prior to the recent 6" lift, and almost all of my alignment tabs were bent flat. Bigger tires and bumps don't mix well with stock cross member alignment tabs.
    Definitely get UCAs. This will allow for proper caster setup. Caster is what causes the wheels to go back to straight after you turn. Not enough caster and your truck will take too long, or you will have to manually center the wheel. But anywhere between 2*-3* is fine.
    ElCidAviator likes this.
  12. Nov 16, 2015 at 9:57 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Sooo... you let go of the wheel and it stays straight? and that's a problem? Sarcasm?
  13. Nov 16, 2015 at 9:58 AM
    Jamintx
    Jamintx Member
    James
    2016 Inferno Tacoma TRD OR
    Camber around zero degrees is fine. Caster around 3 degrees is okay. Make sure there is .5 degrees less caster on the left side to compensate for road crown. A little bit of positive toe is ideal .05 degrees per side. When workin with some of these cam adjusters you just have to work with what you can. Sometimes perfect is not an option. I've worked as a professional auto mechanic for 32 years and have learned some engineers are a$$holes.
  14. Nov 16, 2015 at 10:00 AM
    Unchained 5150
    Rick
    Auburn Ma
    Oh no I meant that I have to go back that sucks sorry man
  15. Nov 16, 2015 at 10:04 AM
    #35
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Haha, ok I get it. It'll be worth it when you get everything dialed in. It took me forever and about 4 alignments to find the best balance using stock UCAs.
  16. Nov 16, 2015 at 10:04 AM
    #36
    Unchained 5150
    Rick
    Auburn Ma
  17. Nov 16, 2015 at 10:30 AM
    #37
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Seriously thinking that of selling mine...
    AE
  18. Nov 16, 2015 at 10:31 AM
    #38
    Arcticelf
    Gladiator
    Good luck. On a related note, with the Camburgs changing the ball joint is easy, so they are worth something.
  19. Nov 16, 2015 at 10:32 AM
    #39
    Unchained 5150
    Rick
    Auburn Ma
    Appointment for 9 A.M. Wednesday morning back to 0.0 Camber and 2.0 to 2.2 Caster
  20. Nov 16, 2015 at 11:15 AM
    #40
    nd4spdbh
    SoCal
    sounds like a good plan!
    wow..... did we just have an entire thread of general agreement and working together?!?! <3 you guys
    rngr, Arcticelf and Arailt like this.
