Alignment
Discussion in 'Suspension' started by churchie76, Nov 11, 2023.
  1. Nov 11, 2023 at 6:31 AM
    churchie76
    churchie76 [OP] Active Member
    2020 Tacoma
    I recently removed a 2" front spacer lift and a 1" rear block off my 2022 Tacoma TRD Sport 4WD. Should I get a alignment done again, or is this not necessary. Thanks for the input
  2. Nov 11, 2023 at 6:33 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Yes you messed with suspension.
  3. Nov 11, 2023 at 6:59 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    If you only removed a rear block then no it wouldn't be necessary. It'll increase your caster a little and honestly probably make it feel nicer to drive. Removing the front spacer, you definitely need an alignment. Your camber and toe probably went very negative and your truck probably now has a stiffer steering wheel and wanders on the road/ has touchy steering
  4. Nov 11, 2023 at 7:01 AM
    churchie76
    2020 Tacoma
    Yeah, it does. I have a alignment scheduled for Monday, but I just wanted to double check beforehand. Thanks again .
    joba27n likes this.
  5. Nov 11, 2023 at 9:25 PM
    camposme
    camposme Well-Known Member
    Ty
    Piedmont Triad - NC
    '16 TRD Sport DCSB
    Fox 2.5 Racing Suspension w/ Resi (ET) OME Dakars (Med Duty) SPC UCAs BAMF Grille TRD Skid TRD Wheels Tom Woods DS
    Great idea! Anytime you mess with the suspension, it's always good to get an alignment. Since you're playing with fractions of an angle, you can help mitigate problems before they start. Solid looking MGM btw! :)
  6. Nov 11, 2023 at 9:27 PM
    RobotTheDog
    RobotTheDog Well-Known Member
    AZ
    21 TRD OR DCSB CEMENT
    All encompassing layer of dust
