Alignment
Discussion in 'Suspension' started by RyleStyle, Feb 15, 2024.
  1. Feb 15, 2024 at 5:46 PM
    RyleStyle
    RyleStyle [OP] Well-Known Member
    California
    2020 TRD Off-Road 4x4 Cement Gray
    I ordered everything I need to lift my truck (finally)
    I have Eibach pro-trucks and an icon AAL for the suspension/ride height. I also have an SPC UCA. I plan on installing the suspension myself, but don't want to do the leaf. If I install the suspension and UCA at my house, do I need an alignment while I wait for an appointment at a shop to put the leaf in? Or is it fine to wait until everything is in?
    Also if I do any sort of adjusting on the coilover after installing and getting an alignment, do I need to get another one?
  2. Feb 15, 2024 at 5:53 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    why hesitant on the leaf? It's no more difficult than the front, probably less so
  3. Feb 15, 2024 at 6:05 PM
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    If you adjust the ride height, I'd personally get an alignment
  4. Feb 15, 2024 at 6:10 PM
    RyleStyle
    California
    Not sure honestly, just doesn't look as easy. Maybe I'll look more into it.
    And what if I don't adjust the Eibachs (assuming they're stock height). I would be switching the tires and wheels though so that probably seals the alignment requirement.
  5. Feb 15, 2024 at 6:16 PM
    SoonToBeOn39s
    When installing a new coilover that is stock height along with a UCA, you should not be touching anything that would mess with the alignment (tie rods, LCA cam bolts) I would say you're good to go, it's relativity simple.
    Edit: I didn't read it was an SPC UCA, I would definitely get an alignment after installing
  6. Feb 15, 2024 at 6:18 PM
    RyleStyle
    California
    I also should add that I have a sway bar relocator kit.
  7. Feb 15, 2024 at 6:19 PM
    Bishop84
    Bishop84 Well-Known Member
    SPC arms 100% change the alignment, you need to get it done right after. There is no factory setting.
    RyleStyle[OP] likes this.
  8. Feb 15, 2024 at 6:19 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    Installing leaves is easy from a technical stand point but if you are doing it solo it is a good workout lifting them into place.
    If you have the tools to do the front then you have all the tools needed to do the rear.
