All 4 wheel-wells sit at different heights..? Could my frame be racked?
Discussion in '1st Gen. Tacomas (1995-2004)' started by defleppardsg, Feb 21, 2012.
  1. Feb 21, 2012 at 1:42 PM
    defleppardsg
    defleppardsg [OP] Well-Known Member
    chris
    texas
    2.7L SR5 4x4
    OME 880's, Wheeler's Offroad 5-Leaf pack. Bilstein 5100's, 1" Daystar shackles, Deck Plate Mod.
    The stance of my truck annoys the hell out of me. Even with brand new springs front and rear, it doesn't sit normal. Each corner sits at a different height. It's not the Tacoma lean, it's not the forward rake... The front passenger side and the rear driver side sit higher than the front driver and rear passenger... On the driver side, I have a forward rake about 1.5" higher in the rear, and on the passenger side, it sits level, and sometimes the front is a bit higher than the rear. WTF Is my frame screwed up? Anyone else notice this on their trucks? It was like this before the new springs and after.
    I've got OME 880's up front, and wheeler's 5 pack in the rear.
  2. Feb 21, 2012 at 1:44 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Twisted man..twisted
  3. Feb 21, 2012 at 1:47 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    A good pic speaks volumes
  4. Feb 21, 2012 at 2:09 PM
    defleppardsg
    chris
    texas
    2.7L SR5 4x4
    Here's some pics. Kind tough to see, because all of the heights are within 1.5" of eachother. But you can see the decent rake on the driver side (desireable) and the level/bro-lean on the passenger (very undesireable).
    Any thoughts?
  5. Feb 21, 2012 at 2:12 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Are you using OME shocks too?
    Did perhaps the trim packer get installed on the passenger side instead of the driver's side?
  6. Feb 21, 2012 at 3:19 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I'm unfamiliar with that leaf pack , but is there any chance it is side specific ? I'm pretty sure the Dakars are side specific for 1st Gens , perhaps these are the same and installed on the wrong sides ?
  7. Feb 21, 2012 at 4:45 PM
    defleppardsg
    chris
    texas
    2.7L SR5 4x4
    I'm running 5100's all around, set at 0". No trim packers or anything. The wheelers 5 pack is side specific. I know that they were installed correctly. The driver's side leaf was arched more than the passenger, supposedly to compensate for Tacoma Lean. That could make some sense. Idk why the passenger front is so high though, it doesn't make any sense.
  8. Feb 21, 2012 at 4:49 PM
    defleppardsg
    chris
    texas
    2.7L SR5 4x4
    Again, the truck had the same odd stance though, even before I redid the suspension. I thought new stuff would fix it but it didn't really. I just have to assume that somehow the frame kinda settled like that, perhaps because of inperfect stock springs.
    I thought about putting a 1/2in block in the rear passenger... wouldnt make all four corners even, but it would at least give both sides a similar front:back rake. Then I'd be pretty much just left with the passenger-to-driver lean again.
  9. Feb 21, 2012 at 4:52 PM
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    Have you run a carfax on it to see if it was wrecked? PM me and I'll see if I can help you with that...
  10. Feb 21, 2012 at 7:04 PM
    defleppardsg
    chris
    texas
    2.7L SR5 4x4
    i bought it from my grandpa, it definitely wasn't wrecked. It was actually taken care of really well. Frame doesn't have any rust either; just passed the frame inspection.
  11. Feb 21, 2012 at 8:51 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I say throw this on the driver's side:
    And then swap the rear springs around and see what it looks like.
  12. Feb 21, 2012 at 8:52 PM
    RenoTacoma
    RenoTacoma Petrol head
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    How level is your driveway? might be planning a small part as well.
  13. Feb 21, 2012 at 9:10 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I see your box and cab line up perfectly, thats a good sign that it isnt twisted (badly at least)
  14. Feb 21, 2012 at 9:29 PM
    scocar
    scocar hypotenoper
    Yes. Unload your toolbox and that gas can first. Also measure when your tank is closer to empty. Also, try measuring hub to fender, rather than ground to fender, to eliminate tire inflation as a factor. Also, go measure it on a dead-level concrete pad, like at a gas station.
    Yes, they are side-specific. OP, just double-check this to be sure.
    Also, during a Wheelers group buy a while ago, someone did get a bum leafpack, and I believe Wheeler's replaced it, but you have to eliminate everything else and be sure before you pursue that path.
  15. Feb 22, 2012 at 1:46 PM
    defleppardsg
    chris
    texas
    2.7L SR5 4x4
    I've tried it all... sometimes I'll see a 1/2" fluctuation, of course, on different surfaces, level or not. but the differences from wheel-to-wheel-to-wheel-to-wheel are always relativeley consistant. Just annoys me that the front passenger is so high.....
  16. Feb 22, 2012 at 1:56 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Battery and gas tank are still sitting on the driver side so your always going to be higher on the front of the passenger side than the driver unless you account for it.
    I still say add a 1/4" spacer to the driver coil and take a look.
    Also you said you've got 5100's, I would verify that both sides are truely set at 0. I don't know who did your install, but I've seen people genuinly screw the pooch when setting up 5100's. Who knows, maybe the spring perch on the passenger side is upside down. And since you do have 5100's, you can always preload the driver coil and set the 5100 up 1 notch to bring the driver side up higher.
  17. Feb 22, 2012 at 2:17 PM
    scocar
    scocar hypotenoper
    Oooh, good catch.
    But wouldn't preloading one side more than the other screw the alignment?
    And on that note, OP, have you had an alignment recently?
  18. Feb 22, 2012 at 3:05 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Everything affects alignment. Hell a fat chick in the passenger seat will affect it. My point being is the OP is obviously not happy with the current setup. I say keep derping with it till he's happy with the stance, then get the alignment.
  19. Feb 22, 2012 at 4:06 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Stupid question for the OP.....
    How are you measuring ride height?
    Reason I ask is you should not be measuring from ground to fender. You should be measuring from center of the hub to fender. Measuring from ground to fender will include discrepencies from tire wear.
  20. Feb 22, 2012 at 4:55 PM
    scocar
    scocar hypotenoper
    That's something I pointed out earlier, too. wear, pressure.
