All blinkers out
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lifetime toyota man, Jun 18, 2020.
  1. Jun 18, 2020 at 7:23 PM
    Lifetime toyota man
    Lifetime toyota man [OP] Member
    Mark
    2016 tacoma
    None
    Hi guys, All my blinkers have gone out all at once. In the past when I have had speedy blinkers you know you have a bulb out. And the remaining blinkers work. This is something new. I have speedy indicators on my dash bot no blinkers work. Thank you in advance
  2. Jun 18, 2020 at 7:43 PM
    Jmac2408
    Jmac2408 Well-Known Member
    Justin
    Southern California
    18 TRD Off Road 4x4
    Check bulbs and fuse. I’ve seen the dual filament bulbs blow and short causing fuse to blow
  3. Jun 18, 2020 at 7:44 PM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    Bad flasher unit
  4. Jun 18, 2020 at 7:45 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Is your truck factory? Have you installed any aftermarket bulbs, load resistors, etc.
    Further information will help us
    Chew, JNG and shakerhood like this.
  5. Jun 18, 2020 at 11:44 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Hope not, those suckers are built in to the Gen3’s!
    Chew likes this.
  6. Jun 19, 2020 at 4:34 AM
    flipnidaho
    flipnidaho Well-Known Member
    2001 Tacoma Double Cab TRD
  7. Jun 19, 2020 at 5:23 AM
    CouchlessPotato
    Zach
    2.5" lift w/35's
    Oh no, that would be annoying. Hopefully just a fuse.
  8. Jun 19, 2020 at 9:20 AM
    Lifetime toyota man
    Mark
    2016 tacoma
    None
    My truck is factory except I replaced a taillight assembly that came with bulbs, I guess I’ll start there. my frustration is usually they don’t all go out at the same time.
    thanks ppl for all the input
  9. Jun 19, 2020 at 10:11 AM
    MESO
    State of Jefferson
    Start with the tail light bulbs
  10. Jun 19, 2020 at 10:16 AM
    Lifetime toyota man
    Mark
    2016 tacoma
    None
    Thank you everyone!!
  11. Jun 19, 2020 at 10:19 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Common area would be in stalk maybe. Do they work with emergency button switch ?
  12. Jun 19, 2020 at 11:22 AM
    Lifetime toyota man
    Mark
    2016 tacoma
    None
    Hi
    No emergency flashers either, but why the ore on I do not get the speedy indicators
  13. Jun 19, 2020 at 11:25 AM
    SoCal TacoOR
    SoCal TacoOR Life at Redline
    Kommie Kali
    17 DCSB TRD OR Super White
    If you live in CA, you don’t use blinkers anyway. Take out the bulbs, save some weight, get better mpg’s.
  14. Jun 19, 2020 at 11:59 AM
    Lifetime toyota man
    Mark
    2016 tacoma
    None
    Same here in ct I’d swear newer cars don’t come with them sometimes
    SoCal TacoOR likes this.
  15. Jun 19, 2020 at 3:29 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    hell yeah, weight reduction :cool:
  16. Jun 19, 2020 at 5:47 PM
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    Grossomotto likes this.
  17. Jun 22, 2020 at 6:53 AM
    Lifetime toyota man
    Mark
    2016 tacoma
    None
    Hi
    Guys, update on my blinkers. It is not the bulbs. Bulbs work but do not flash. Interesting note. When truck is off the dashboard indicators flash normal speed but when started they flash fast
    Skydvrr likes this.
  18. Jun 22, 2020 at 9:12 AM
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    If a bulb is bad, it can cause that. Start replacing them and I bet you will find one that fixes it.
  19. Jun 22, 2020 at 12:44 PM
    Lifetime toyota man
    Mark
    2016 tacoma
    None
    Thank you
    I start replacing
  20. Jun 22, 2020 at 2:54 PM
    Lifetime toyota man
    Mark
    2016 tacoma
    None
    Hi guys, I went looking for the master relay, could not find. Took to dealer. Turns out the master relay is in an electrical cluster to the tune of about $700.
    thank for all the input
