All fuel injectors bad?!
Discussion in '3rd Gen. Tacomas (2016+)' started by AthensTac, Jan 8, 2019.
  1. Jan 8, 2019 at 5:29 AM
    AthensTac
    AthensTac [OP] Member
    CB
    Quicksand 4-door TRD sport
    Hey all, This is a long post......I have a 2017 DCSB Sport with just under 31,000 miles. Have had zero issues with it. This past Fri I was running errands, so truck was shut down and re-started several times. Last stop was finished, started truck and check engine light came on with Trac-off light. Turned off the truck, waited a few, started, lights still on and now idle started surging from about 1000 rpm to so low engine almost died. Called hubby, and while he was on his way I called my Toyota dealer service dept. (No help other than offered to make an appointment... ) Hubby arrived, I started the truck, lights still on but idle was good, so decided to try to drive it home. As soon as I gave it gas, it tried to die. So headed back to the parking lot, and then it did die as soon as I accelerated. Discovered if I feathered the gas pedal it would keep running, sort of. Parked it in the first parking space, locked it up and went home. Sat morning called AAA for tow and had it taken to Toyota. Got a call from service advisor yesterday and he said it took them a while to figure out what was going on, but it seems all 6 injectors are bad and they will be replacing them..... Neither my husband or myself nor any knowledgeable friends have ever heard of all the injectors going bad at the same time, esp with NO prior indications. Truck was running normal before it was shut off. Opinions? (other than Toyota is just guessing?)
  2. Jan 8, 2019 at 5:37 AM
    bulalo
    bulalo Well-Known Member
    2017 trd offroad 4wd LB
    none at the moment
    My guess it’s the cps sensor gone bad. Just can’t understand why all 6 injectors going bad in a new truck
  3. Jan 8, 2019 at 5:38 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Seems highly unlikely. Generally service writers are not mechanics but they are good at coming up with stories.
  4. Jan 8, 2019 at 5:39 AM
    AthensTac
    CB
    That would certainly make more sense.... or maybe even a fuel injector pump....
  5. Jan 8, 2019 at 5:43 AM
    MOC221_
    MOC221_ 3rd Gen GinGer StepchilD
    Frank
    2016 OR AC 6MT
    OVT 1.05 MA 91
    Be nice to know what those codes were b4 the dealer got their hands on it. All injectors at the same time doesn't sound right.
    Low pressure fuel pump, it's ECU, harness, or even HPFP.
    CKP on ignition side..
    Need the codes lol
    AthensTac [OP] likes this.
  6. Jan 8, 2019 at 5:43 AM
    Saeros
    Saeros Well-Known Member
    Vancouver, BC
    2017 Tacoma TRD OR DCSB
    275/70R16 KO2s, Fox 2.0 factory series coilovers, Fox 2.0 Performance Series Shocks, OVTuned, Black badges (Painted original chrome)
    What I find confusing is... Your truck has 12 injectors. What about the other 6?
    MoneyMan55, 02Duck and Stocklocker like this.
  7. Jan 8, 2019 at 5:44 AM
    AthensTac
    CB
    hmmmmmmm
  8. Jan 8, 2019 at 5:47 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Bad fuel injectors don't throw a code.
    That dealer is shooting parts and blowing smoke.
    Please keep us informed.
    MOC221_ and AthensTac [OP] like this.
  9. Jan 8, 2019 at 5:51 AM
    MOC221_
    Frank
    2016 OR AC 6MT
    OVT 1.05 MA 91
    A very good point.
    Watching the proper PIDs with techstream, unless the truck is in it's DI "cleaning mode" the injectors being used at hot idle are port (makes sense).
  10. Jan 8, 2019 at 5:52 AM
    MOC221_
    Frank
    2016 OR AC 6MT
    OVT 1.05 MA 91
    That may be true, but you'd probably set codes as a result of bad injectors. Missfire count for one.
  11. Jan 8, 2019 at 5:53 AM
    koditten
    Kirk
    Central Michigan
    Yep. Exactly.
  12. Jan 8, 2019 at 5:56 AM
    koditten
    Kirk
    Central Michigan
    The only "bad" injectors I've seen are leaky injectors. Those symptoms were not reported by the OP.
    The problem is going to be an electrical issue. Anything else would have produced some previous symptoms.
    I'm leaning towards the CSP.
    rjbiii likes this.
  13. Jan 8, 2019 at 5:59 AM
    rjbiii
    rjbiii Alleged Member
    Robert
    SATX
    '09 ACLB 5spd PreRunner & '13 DCSB 6spd 4x4
    stock
    As others have already said, it's highly unlikely that it's ALL the injectors. More than likely the CPS
  14. Jan 8, 2019 at 6:03 AM
    Resqu2
    Resqu2 Well-Known Member
    Rick
    SW VA
    2018 Tacoma TRD Off-road
    AVS Aeroskin bug shield, TufSkinz tailgate letters, tinted windows, Undercover Ultraflex bed cover.
    So I’m guessing this will all be covered by warranty so let them throw a bunch of new parts on it till they fix it. Good luck, hope they fix it quick for you.
  15. Jan 8, 2019 at 6:26 AM
    skiploder
    skiploder Personally holding a grudge against Falken
    Under a piece of wood
    Taco/4Runner
    Good news is that it's under warranty.
    You'll find out soon enough whether or not it's the injectors.
    BillsSR5 and AthensTac [OP] like this.
  16. Jan 8, 2019 at 6:27 AM
    AthensTac
    CB
    Fortunately it’s under warranty they say.... if it wasn’t, it would be taken to a regular mechanic...
    Resqu2 and Saeros like this.
  17. Jan 8, 2019 at 8:15 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    North Carolina
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs
    you should also have Toyota towing included in the factory warranty period, just an FYI, replaced my CPS just in case, but never heard of all 6 going bad? maybe one?
  18. Jan 8, 2019 at 8:19 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    What you're describing is classic symptoms of the Crankshaft Position Sensor failure. If you look at the service manual, you'll see that without this sensor working properly, your truck can't actually tell how fast your engine is spinning (RPMs) which of course in turn affects ignition and fueling. Mine was dumping ridiculously rich at times then super lean at others before I replaced mine (also on a '17) and the dealer was clueless. Glad I just replaced it on my own before something like this happened. $100 part and 10 mins of your time if the dealer doesn't figure it out
    Toyko Joe, AthensTac [OP] and KVTaco like this.
  19. Jan 8, 2019 at 8:32 AM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    This is exactly your problem OP... I would change service centers when your warranty runs out as this one has no clue or is setting you up for unnecessary expenses in the future.
    AthensTac [OP] and Taco_Craig like this.
  20. Jan 8, 2019 at 9:29 AM
    CementHead18
    CementHead18 Member
    Jim
    Lancaster, SC
    2018 CementTRD Sport 4x4 DCSB
    Don't know about anyone else but I wouldn't feel all that comfortable with them replacing 6 factory installed injectors after coming up with a lame diagnosis as that... all six at once doesn't happen... surprised they didn't blame the carburetor.
