All Hybrids made in Guanajuato?
Discussion in '4th Gen. Tacomas (2024+)' started by Mexmeno, Jul 3, 2024.
  1. Jul 5, 2024 at 1:14 PM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    Yeah, wrong place. Funny thing is the RoC as you are calling it is the 5th largest economy in the world and nearly 15% of US GDP. I can assure you it is quite capitalist.
    soggyBottom, guest_707 and jackn7 like this.
  2. Jul 5, 2024 at 1:34 PM
    Mexmeno
    Mexmeno [OP] Well-Known Member
    Ontario Canada
    23 TRD Off-road
    Ok good to know, I thought Guanajuato was the better of the two plants.
  3. Jul 8, 2024 at 5:50 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    The motor generator in the Hilux 48v is under the hood and belt driven not sandwiched between the engine and transmission like the 4G Tacoma. The Hilux is also using its existing 6spd transmission.
    NEW 48V TECHNOLOGY
    The powerful 2.8 litre Hilux diesel engine has been strengthened by the addition of a hybrid 48V system specifically designed for the unique demands of Toyota’s dual use pick-up.
    The engine drives a compact motor generator using a belt system, which in turn charges the new 48V lithium battery, which is small enough to be installed under the rear seats to minimise impact on cabin space, and weighs just 7.6 kg. This 48V battery also supplies the vehicle’s 12V system through a new DC/DC converter.
    Like Toyota’s full hybrid electric systems, the new battery is charged during deceleration, efficiently regenerating braking energy which would otherwise be lost, whilst also adding additional braking performance. Once charged, the battery sends up to 16 DIN hp (12 kW) of power and 65 Nm of torque through the motor generator to the engine to enhance acceleration, power and efficiency.
    The robust motor generator is compact and has been designed to withstand the harsher working environments experienced by commercial vehicles, while the engine has been modified to adapt to the hybrid system. A new two-arm belt tensioner and stronger belt material contribute to the improved drivability and a quieter ride, whilst retaining Hilux’s famous durability.
    Combining with the motor generator is the powerful and proven Euro 6d-compliant, DOHC, 16 valve, 2.8-litre diesel engine which generates 204 DIN hp (150 kW) at 3,400 rpm and 500 Nm of torque between 1,600 and 2,800 rpm.
    It is equipped with a common rail fuel injection system, a variable nozzle turbocharger and a water-cooled intercooler. Exhaust emissions control measures include a Diesel Oxidisation Catalyst, a Diesel Particulate Filter, Selective Catalytic Reduction (SCR) and Urea Additional Injection.
    In common with existing Hilux, Land Cruiser and PROACE family of vehicles, the Hilux Hybrid 48V is compatible with HVO100 diesel, a non-fossil fuel made from 100% renewable sources.
    https://newsroom.toyota.eu/new-hilux-hybrid-48v-enhances-an-invincible-icon/
