All In one Remote Key GQ43VT20T
Discussion in '2nd Gen. Tacomas (2005-2015)' started by neneago, Oct 2, 2014.
  1. Jan 8, 2015 at 6:57 PM
    #441
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    I'm assuming yours was chipped right?
  2. Jan 8, 2015 at 7:00 PM
    #442
    neneago
    neneago [OP] Well-Known Member
    Sugar Land, Texas
    Thanks guys.
  3. Jan 8, 2015 at 7:01 PM
    #443
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Well his all in one key is much longer than the OEM key, as it incorporates fob controls into the key itself. I'm not aware of an option that matches your needs in whole, but maybe in the mean time you consider removing the key from your pocket while working? String it on some paracord or something and put around your neck? Put it in your boot sock?
    Not ideal, but 10 cents of cordage and you'll save a key from needing replacement after bending in your pocket. I'd get creative.
  4. Jan 8, 2015 at 7:07 PM
    #444
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    reading between the lines here, you need help. :rolleyes:
    yup, both of them.
  5. Jan 8, 2015 at 7:09 PM
    #445
    WeberSarge
    WeberSarge Well-Known Member
    Kevin
    Ohio, Illinois
    '08 SR5 TRD 4X4 Quad Cab , '77 FJ40
    Stock for now...
    I've tried a lot of things like that - original key ended up in a crusher , #2 key was in my lunchbox when a tandem driver ran it over - drove the key into the asphalt in pieces . This seems to be a trend with automakers - those keys just keep getting bigger . I mostly drive the Cruiser to work , tough to hurt that thing and most people can't figure out how to start it anyway .
    I wasn't aware his key was longer than an original - the pictures look like the handle portion is the only difference - not length overall which would not work . I either gotta figure something out or get rid of the truck . Tired of paying for new keys to be made/programmed and the key/fob design of their original is a joke .
    Sarge
  6. Jan 8, 2015 at 7:11 PM
    #446
    T4RFTMFW
    Tried looking up strong car keys, found none. So Weber I'd consider strongly moving the key out of your pocket to somewhere that won't be bent and twisted constantly (like a boot sock?) or pick up a Hitch Safe or something for your key to go in. Not sure where these rough areas are that nukes are planted in, but nonetheless, chances are where there's nukes there's cameras. If someone wants to steal your rig then it'll get taken, for the cost of 3 key replacements you could buy a Hitch Safe (assuming you have a receiver).
    Flip key definitely isn't the way for you to go, though.
  7. Jan 8, 2015 at 7:14 PM
    #447
    T4RFTMFW
    I believe the shank is the same length as OEM and the fob portion is larger than the OEM rubber area, but I'll let him answer that as I have only best guesses.
    Maybe you should re-key the Tacoma to match the Cruiser key, and remove the transponder and put it elsewhere like Skygear (member on TW) has done. In fact, you might scroll back a few pages and see his key setup, maybe that'll be something you can do as an option. His key is minimal.
  8. Jan 8, 2015 at 7:35 PM
    #448
    neneago
    Sugar Land, Texas
    Like I've said many times before... I don't see the big deal of flip keys. Usually more bulky and more stuff on them to break.
  9. Jan 8, 2015 at 8:55 PM
    #449
    wanna taco
    alan
    SF Bay Area
    A question on that please? The transponder just need to be in the truck, or close to the ignition switch, or how far away works?
  10. Jan 8, 2015 at 9:29 PM
    #450
    neneago
    Sugar Land, Texas
    Transponder has to be about 1“ or closer to the ignition.
  11. Jan 8, 2015 at 9:38 PM
    #451
    neneago
    Sugar Land, Texas
    No. Don't get confused. I use OEM chips.
    You wanted to send me your key to copy it. That will require me to program the key onto a CLONE chip. Clone chips have weaker antennas.
    Oem chips require self programming(some models) OR connecting computer to car.
  12. Jan 8, 2015 at 9:40 PM
    #452
    T4RFTMFW
    Go back a few pages and see Skygear's keyring.
  13. Jan 8, 2015 at 9:43 PM
    #453
    wanna taco
    alan
    SF Bay Area
    I saw that, didn't see a transponder? I'd really like one of those itsy bitsy lighters tho! What were the magnets for anyhoo? That's a bunch of stuff yo have on a keyring!
  14. Jan 8, 2015 at 9:44 PM
    #454
    T4RFTMFW
    His transponder is elsewhere so his kids can't start his truck.
  15. Jan 8, 2015 at 9:47 PM
    #455
    wanna taco
    alan
    SF Bay Area
    Yeah... he didn't say it was on the keyring... you told me to look there. :smack:
  16. Jan 8, 2015 at 9:55 PM
    #456
    skygear
    skygear                    
    0df019723d4e6faecbb640c9e4483e50_7e47d795b1a4c9a7f5ab1e74acca33c648b5c3e0.jpgaafa1047eeb9cb6e05ee6dce98e2ca21_7855642d67405f20e352746d548c3b2920b0e3a7.jpg47599f07fc2f1f1b09a2549a9dbfb3ee_1224cd93d6d25d16e9ede58aaf29aa089b5476e1.jpg
    When you Start the truck. On my 05 the immobilizer doesn't check again once it is started.
  17. Jan 8, 2015 at 9:56 PM
    #457
    T4RFTMFW
    I love that you covered your fingerprints.
  18. Jan 8, 2015 at 9:58 PM
    #458
    skygear
    skygear                    
    Aint no one getting them ridges. :brianr:
  19. Jan 9, 2015 at 7:41 AM
    #459
    WeberSarge
    Kevin
    Ohio, Illinois
    Stock for now...
    Now that's some interesting info ....
    The keys are getting destroyed mostly on Heavy Highway jobs , or when doing pipe bores and welding casing pipe . I work a really wide variety and sometimes end up near some of the cities -hence the truck being locked all the time . Not to mention , many times I'm 20+ miles away from it with a crew somewhere . We get a ride to wherever we could park our vehicles , sometimes they even get vandalized and one had been stolen - he left his keys in the nearly-new car , dumb .
    The weak nature of the flip key is understandable and I agree not a decent solution . So far , best way has been to remove the remote lock fob from the key and keep that smaller part in my pocket and leave the key somewhere in the truck . But , it's been a pain and just looking for a simpler key design . May just try his standard 3-button version since it looks to be close enough in size and at least beefy enough . Two of those is way cheaper than 1 key from the dealer - what the heck ....
    Sarge
  20. Jan 9, 2015 at 9:29 AM
    #460
    neneago
    Sugar Land, Texas
    Sarge.... Stand by on the flip key. Will get new design next week. I'll test it and send you out a unit for you to test FREE. Your the perfect candidate to test the new design.
