All In one Remote Key GQ43VT20T
Discussion in '2nd Gen. Tacomas (2005-2015)' started by neneago, Oct 2, 2014.
  1. Sep 13, 2020 at 5:30 PM
    #1281
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    did you have to program anything? my 2010 has a dot on the key indicating it’s chipped.
    i see you have a 2012? did you have a chip in your key?
  2. Sep 13, 2020 at 5:34 PM
    #1282
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    Yes, chip is required. The key in the foto has a slot to hold the chip. I previously had bought an aftermarket key and had coded it to my truck.
  3. Sep 14, 2020 at 12:40 PM
    #1283
    dewald1
    dewald1 Well-Known Member
    Maryland
    24 TRD OR
    Did you /could you use the guts from your original fob in this key?
  4. Sep 14, 2020 at 12:48 PM
    #1284
    apoteker
    I had purchased a 3rd OEM remote (and aftermarket key and added it to my truck before buying this new flipkey fob. The OEM circuit board fits in without any modifications- it simply drops in.
  5. Sep 14, 2020 at 1:02 PM
    #1285
    dewald1
    Maryland
    24 TRD OR
    Oh nice, I see that reply, thanks man!
  6. Sep 16, 2020 at 12:21 PM
    #1286
    volte
    volte Well-Known Member
    Dale
    Denver
    2014 Magnetic Grey Tacoma TRD OR 4x4 V6 MT
    ICON Stage 9 Lift
    Yea mine came last week. It's quite low quality, and a lot larger than I expected it would be. It was cheap, so I probably won't return it. If anyone wants to pay for shipping I'll ship it to ya. (80221). I want a AIO keyfob that isn't substantially bigger than both the remote and key combined (which this is, and then some). Still not really sure why this one didn't work... I thought the "G chip" meant it was compatible...
  7. Sep 16, 2020 at 12:52 PM
    #1287
    dewald1
    Maryland
    24 TRD OR
  8. Sep 16, 2020 at 1:51 PM
    #1288
    volte
    Dale
    Denver
    ICON Stage 9 Lift
    Do you happen to know if there are any other factors involved with these? If "G Chip" and "315mhz" are the main factors, what else could be causing the one I got not to work? Granted, mine doesn't mention 315mhz...
    EDIT 1: I just took this Key Fob apart, and googled some numbers on the PCB ("251451-313") and found this link: https://www.aliexpress.com/item/4000232081604.html which clearly states 314.4mhz. I'm no EE, so I'm not sure if this counts as 315mhz or not... this one specifically states 315mhz... might be worth a try, depending on if someone can answer the 314.4 vs 315 question...
    EDIT 2: Aaaaannnnddd... then there is this one which is exactly what I'm looking for. Gonna give it a shot—explicitly says it works with Tacoma 2014.
    TxStVanWilder likes this.
  9. Sep 16, 2020 at 5:39 PM
    #1289
    TxStVanWilder
    TxStVanWilder The Pale Horse
    Tx
    2013 TRD Sport
    Figured id try it out and bought one too.... Ive been looking for something like this since i bought my truck
  10. Sep 16, 2020 at 7:13 PM
    #1290
    dewald1
    Maryland
    24 TRD OR
    Yea, so I wasn't sure which version of key I had and after researching online I still wasn't positive. I have a 08 base model without the immobilizer. They were cheap enough so I just ordered both the 4D67 and g chip version with 315 mhz, and the g chip one was able to be programed
  11. Sep 16, 2020 at 7:17 PM
    #1291
    dewald1
    Maryland
    24 TRD OR
    I thought about one like this but didn't care for the trunk button.
  12. Sep 16, 2020 at 7:22 PM
    #1292
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I like this!
  13. Sep 16, 2020 at 8:49 PM
    #1293
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    It's been a little over 4 years since I bought mine (that's still working well), but this is what it looks like and it's (still) listed as compatible with "2011-2017 Toyota Tacoma Tundra."
  14. Sep 17, 2020 at 2:57 AM
    #1294
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    well is it? lol
  15. Sep 17, 2020 at 8:49 AM
    #1295
    Norton
    No idea what you're asking.
    Mine works great, so I don't need another one. This one APPEARS identical, meets most folks' requirement for relatively compact size, and claims to be compatible. Obviously, YMMV.
  16. Sep 17, 2020 at 8:59 AM
    #1296
    TegoTaco
    Ontario, Canada
    wrong post...sorry man!
    Norton[QUOTED] likes this.
  17. Sep 21, 2020 at 7:41 PM
    #1297
    volte
    Dale
    Denver
    ICON Stage 9 Lift
    Welp, mine arived today, and I was unsuccessful in programming it. I got the 4 action (2 lock, 2 unlock) response. I have an eBay question out to the seller. We'll see what they say.
    With any luck getting the actual three buttons working, my goal is to fiddle around with some things and see if I can't get the trunk button to work on a Pop&Lock setup :)
  18. Sep 21, 2020 at 8:22 PM
    #1298
    G-shock!
    G-shock! Well-Known Member
    OC TACOMAN
    Orange County
    2GTRD4L
    Fox 2.0 frt/resi rr PolyPerf. UCAs
    Please give us an update! I want the same damn key...
    on a side note the eBay seller you bought the key from had three positives and one negative feedback on the key on this specific Tacoma key. eBay feedback doesn't say if they got it working or not... Here is the negative feedback that was left.
    "BEWARE!! REMOTE PART WORKED, BUT 2 LOCKSMITHS CONFIRM BAD CHIP FOR KEY IGNITION
    Upgraded Flip Remote Key Fob 315MHz G Chip for 2011-2014 Toyota Tacoma GQ43VT20T (#183790829850)"
  19. Sep 21, 2020 at 8:26 PM
    #1299
    volte
    Dale
    Denver
    ICON Stage 9 Lift
    Hmm. I see no reviews for this eBay seller but eBay is also terribly designed so I might be doing something stupid. I'll certainly keep y'all posted on what I find.
    Edit: Derp. I see the feedback (not reviews, you did say feedback).
  20. Sep 22, 2020 at 7:26 AM
    #1300
    volte
    Dale
    Denver
    ICON Stage 9 Lift
    The seller got back to me and writes:
    And then attaches these two photos. Not really sure why the trunk button matters in this case. If the mhz are correct and the chip is correct, shouldn't it work? I mean... what Tacoma comes with a keyfob that has a trunk button anyway?
    I might try taking it to a locksmith or maybe even a dealer and seeing if they can coerce it into working. I'll be sure to ask lots of questions along the way and see if I can figure out what they're using to make it work.
    [​IMG][​IMG]
