All In one Remote Key GQ43VT20T
Discussion in '2nd Gen. Tacomas (2005-2015)' started by neneago, Oct 2, 2014.
  1. Sep 22, 2020 at 5:51 PM
    #1301
    G-shock!
    G-shock! Well-Known Member
    OC TACOMAN
    Orange County
    2GTRD4L
    Fox 2.0 frt/resi rr PolyPerf. UCAs
    A locksmith told me to order this key for my 2014 DCSB on eBay item#373052463464 and said he can program it. I have my doubts right now but it is a three button.
    Specifications:
    Condition: New, never used replacement part
    Type: 3 Buttons Key fob with electronics
    FCC ID: GQ4-52T and Part 89071-0R040, 89070-0R120, 89070-0R130
    FIT:
    2014-2019 Toyota Highlander
    2013-2018 Toyota Rav4
    2018-2019 Toyota Sequoia
    2016-2019 Toyota Tacoma
    2018-2019 Toyota Tundra
    Package includes:
    1 x Replacement Keyless Entry Remote Key Fobs
    Features:
    - Complete electronic assembly with battery.
    - Durable long-lasting construction, easy to use.
    - It is a 315MHz remote with 3 buttons.
  2. Sep 24, 2020 at 3:32 PM
    #1302
    volte
    volte Well-Known Member
    Dale
    Denver
    2014 Magnetic Grey Tacoma TRD OR 4x4 V6 MT
    ICON Stage 9 Lift
    Just had a locksmith tell me the same thing. He wasn't able to program the one I got, and thinks it's due to having four buttons. He said according to his book, they shouldn't be listing RAV4 on those. Grr. I think I'm going to buy the cable and see if I can monkey around with these things myself.
  3. Sep 24, 2020 at 6:03 PM
    #1303
    dewald1
    dewald1 Well-Known Member
    Maryland
    24 TRD OR
    Does anyone know exactly how to tell what chip or lack of that each Tacoma model is equipped with?
  4. Oct 26, 2020 at 1:56 PM
    #1304
    stonylaroux
    stonylaroux Well-Known Member
    Seattle, WA
    2015 Toyota Tacoma TRD Offroad
  5. Oct 29, 2020 at 3:26 PM
    #1305
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
  6. Feb 4, 2021 at 11:17 AM
    #1306
    jtaco11
    jtaco11 Well-Known Member
    Most likely the simplest solution w flip. Transfer inside from old fob & cut out the chip from old key (theres a slot chip). I do want the key w/ fob attached at bottom tho but programming might be an issue.
    $10 + another $5-10 to cut maybe.
    https://www.ebay.com/itm/for-Toyota-Sequoia-Sienna-Tundra-Tacoma-Upgraded-Remote-Key-Shell-Case-GQ43VT20T/313327465898?ssPageName=STRK%3AMEBIDX%3AIT
  7. Feb 4, 2021 at 11:21 AM
    #1307
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    saw this few months ago.
    altho i don’t think i want to hack my key apart to get the chip out risking breaking it
  8. Feb 4, 2021 at 11:24 AM
    #1308
    jtaco11
    one my keys worn can be pulled out w ignition acc/on & cant unlock manually so i might try cutting the chip out.
  9. Feb 4, 2021 at 12:24 PM
    #1309
    Muddinfun
    Muddinfun Well-Known Member
    Go to the dealer with the registration and your matching ID and ask the for the key code by VIN. They will look it up in the computer and give you a key code. Don't have the dealer make you a key. They're not locksmiths and can't be trusted to cut it correctly. Take that key code to a locksmith and have them cut you a cheap $7 all metal key. That key won't start your truck, but then you will have a nice new key that you can work off from. Try your new key in the locks. If it works good then you can decide which immobilizer option you want to go with. If it doesn't work good, then you need to have the locks worked on by the locksmith.
  10. May 17, 2022 at 12:50 PM
    #1310
    volte
    Dale
    Denver
    ICON Stage 9 Lift
    toyoda_fan[QUOTED] likes this.
